Two GD00Z-4 Garage Door Opener Remote Controllers - One opens via HA; one does not
I have one two GD00Z-4 Garage Door Opener Remote Controllers. My wife’s side which was the first I added works perfectly.
My side beeps but the door does not open.
Any insight?
Are they both new? Can you confirm they have been both added securely?
Are they Connected to same type of openers? What model?
They a few years old. Previously connected to a Wink hub, but have been excluded and reset.
Yes, both added securely. Same set up on each garage door as far as equipment goes.
I would verify the tilt sensor is paired, and battery not dead… there Is a few similar issues here, but doesn’t sound promising
Also, if you haven’t manually cycled the door recently that helps if got out of sync or anything
I’ll give it read. Thank you!
