Why do I see two HomeKit bridges and what is the difference?
HASS Bridge J0AX:51828
Home Assistant Bridge:51827
Under Configuration > Integrations, do you have more than one instance under the HomeKit integration? If so, each acts as a separate bridge. For example, I created separate bridges for Lights, Switches, etc:
I have two bridges but I’m unsure why
Click into them and see what devices are associated with each. Or just remove them if you don’t need them.
There are no devices listed under bridges. Is it a bug or feature?
Did you add any domains or devices? Click on the bridge and then click the configure button and follow the steps…
