I’m using a sonoff zigbee dongle, and the ZHA zigbee integration. (and Mosquitto broker MQTT)
I added both blinds to Home Assistant using ZHA. One is added with a quirk listed next to it, as per the screenshot. The other didn’t get that quirk when it got added. Only the quirk one works properly (responds to commands from the HA interface). I have removed and added the non-quirk one a few times trying to get it to appear with that quirk, but with no luck. They are both using the same firmware, and both had been added to the xiaomi mi home cloud previously using an aqara zigbee wifi hub, but it was unreliable controlling them via HA using that integration and I wanted to keep things local where possible.
Is there a way to manually add the quirk? is there something else I might be doing wrong?
