Hello everyone,
How can I add two identical integrations in Home Assistant? I would like to visualize two different API data using HA. When adding a new integration, I only get the message that one has already been created. Thanks!
Hello everyone,
Which integration?
Tibber. We live in a semi-detached house with two separate electricity contracts, both of which I would like to manage in Home Assistant.
It seems that the current Tibber integration only supports one instance so you can’t add a second entry.
Yes, that is exactly my problem. Can I possibly duplicate the installation files and then enter the other API key there? If so, where are the files located, I can’t find them in the folders. …
If you feel comfortable with it, you can try to manually add a second instance via \config.storage\core.config_entries at your own risk. I’m not sure if that works, you would have to do some more research yourself or ask the developer if multi instance could be added.
Okay, thanks anyway!
