cannfoddr
(Cannfoddr)
1
I added a NeoCoolcam PIR a few weeks ago, renamed the node and some sensors and I ended up with:
node_id: 20
node_name: Hallway PIR
product_name: Battery Powered PIR Sensor
query_stage: CacheLoad
I just added an identical device that arrived this week and:
node_id: 22
node_name: Neo CoolCam Unknown: type=0003, id=108d
product_name: Unknown: type=0003, id=108d
query_stage: Dynamic
I cant seem to get a rename to take any suggestions?
dap35
2
Take a look at the entries in your zwcfg…xml file for these two devices. It looks like the second one is different (newer) and has a different i.d.
If that is the case, you can stop HA and edit the zwcfg file to update the missing entries, then restart HA.
cannfoddr
(Cannfoddr)
3
That fixed it thanks…had to hunt down the files in Docker image…
/usr/local/lib/python3.6/site-packages/python_openzwave/ozw_config/
/usr/local/lib/python3.6/site-packages/python_openzwave/ozw_config/config/
there is a manufacturer xml file that I edited to add the new id.
