I have three Aeotec Multisensor 6 devices; sensors A, B and C. All three work on USB power so battery mode wakeup timer shouldn’t be an issue.
Through editing zwcfg_blabla.xml, I have manually set the following values for all three sensors:
- Temperature reporting threshold: 5 (default was 20; 2.0C)
- Group 1 Reports: 32 (Temperature)
- Group 2 Reports: 64 (Humidity)
- Group 1 Interval: 60 (every minute)
- Group 2 Interval: 600 (every 10 minutes)
Looking at History (and home-assistant_v2.db), however:
- Sensor A temperature logging interval varies between 1 to 40 minutes
- Sensors B & C only log temperature once an hour (almost exactly)
For sensor A, roughly half of the logged 50 values were at a 1 minute interval. 7 were at 2 minute interval, 3 at 3 min, and the rest stretch from 5 to 40 minutes. Each time, the change in logged temperature has been 0.1 C, even at 1 minute interval.
Why does it not stick to 1 minute? I might increase it to 10 minutes anyway, but I’m curious why the interval sometimes goes so far over the set interval?
Sensors B and C are the main issue here though; despite the settings I’m getting a temperature logged exactly every 1 hour.
I then took all three nodes from the xml file to Excel and performed a row-to-row comparison, and the only differing rows are either the Node row (with id, name etc), SensorMap (where type is unique for each), or some of the Value rows (luminance, temperature, etc current values).
The only significant difference appears to be this:
Sensor A: Protocol Version: 4.54, Application Version: 1.11
Sensor B: Protocol Version: 4.05, Application Version: 1.08
Sensor C: Protocol Version: 4.05, Application Version: 1.08
I did indeed update the firmware on sensor A, while it was being used in an earlier setup before sensors B and C arrived. Do you think this could be the cause?
I read that FW 1.11 introduced these changes, of which number two could be relevant? I did check that the config lines for parameter 41 were identical in all the three sensors before I made changes…
Unfortunately, the firmware update requires a Windows PC (Z-Stick), so it’s impossible to do remotely. As the system is about 125km (78 miles or so) from me, I’d rather not drive there unless out of options.
Any ideas on what to look for next?
