I’m looking for a how to, to set up two servers to be able to access them both remotely. Can someone point me in the right direction?
Thx
D
Sorry, I’m not entirely sure if this is what you are looking for, but you can use the HA Companion App to understand there are two different HA instances/servers, and within the Companion App, you can select which server you want the App to talk to. This allows you to go back and forth between the two HA servers.
Yes that is what I want to do. My plan is to have at home and one at y oat.
In case you were looking for it, in the Companion App, goto Settings->Companion app and at the top should be row titled “Add Server”.
