I was forced to change my Home Assistant Yellow. I installed a new CM4 with more memory and moved the data NVMe SSD to the new Home Assistant Yellow. I then restored HA on the basis of a full backup.
When I restarted the new Home Assistant Yellow, the system identified my data disc and I had to confirm the Zigbee channel used previously.
Now I have two Zigbee coordinators in the list of devices and slowly I lose the connection with my other Zigbee devices.
Does anyone have a solution to correct this? Thank you in advance for your comments and help.
