Short version
Looks like a simillar problem. all of my sensors are detected, but their addresses are mapped to different names
Can anyone please advise
Long version
in my boiler room I have two busses of DS18B20. 14 and 15 sensors each. all sensors are the waterproof type. and currently connected to two separate esp8266 based 8 relay boards with custom Tasmota build (to enable more than 8 sensors and DS18Aliasing). Uses UTP cable and 4.7K pullup to 3.3v. powered from 3.3v.
They all worked like this for over a year. the only problem was the occasional loss of sensors after power outage, which in my opinion is related to the fact that on power restore some relays trigger and draw too much power hence the DS18B20 fail to initialise. After soft reset they initialise fine.
Now I want to migrate the temperature sensors to ESPhome. wired (with data pull up), prepared the yaml with all the addresses:
esphome:
friendly_name: hvac-sensors1
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
baud_rate: 0
level: DEBUG
# Enable Home Assistant API
api:
encryption:
key: "redacted"
ota:
password: "redacted"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "redacted"
password:"redacted"
captive_portal:
web_server:
port: 80
dallas:
- pin: GPIO21
update_interval: 5s
- platform: dallas
address: 0xD3062261522A4828
- platform: dallas
address: 0x42011447E180AA28
- platform: dallas
address: 0x6E0114480720AA28
- platform: dallas
address: 0xEC0114482F52AA28
- platform: dallas
address: 0x3B01144865F6AA28
- platform: dallas
address: 0x4F0114488ED1AA28
- platform: dallas
address: 0x400114485219AA28
- platform: dallas
address: 0x770114478E3BAA28
- platform: dallas
address: 0x8806226181A1FA28
- platform: dallas
address: 0xC00621946B139128
- platform: dallas
address: 0xCC0621946D64E928
- platform: dallas
address: 0xF00621945C000D28
- platform: dallas
address: 0x540621945C66ED28
- platform: dallas
address: 0xA306226168B38328
- platform: dallas
address: 0x0506226178652328
The same addresses are used in Tasmota’s DS18Aliases to map sensors to their names.
When I connect any of my two busses I see readings from one sensor shown on another sensors name. I cross checked this comparing to tasmota readings, and with immersion of sensors to cold water. some of them show correct valuaes others show values from different sensors than the names are mapped to.
in the image below: left Tasmota (all correct values) right ESPHome. the screenshots are taken at slightly different time because I needed to move the Dallas buss from one device to another (the temperatures are supposed to be a bit different (this is a live system)).
green - correct value
Orange - the value ESPHome was supposed to show
Red - the value ESPHome actually shows.
What I tried:
- changed the pull up from 4.7K to 2K. Problem persised
- changed the Dallas voltage from 3.3v to 5v (the pullup remained to 3.3v). Problem persised
- tried changing the dallas bus pin. Problem persised
- tried some different approaches to Yaml recommended over the years on community forums.
- changed update_interval to different durations. Problem persised
- tried external component dallasng instead of dallas.
- tried both of my dallas busses. they have different counts of sensors and different lengths between them. Both busses have the same problem.
here are some very_verbose logs:
[20:06:28][C][dallas.sensor:075]: DallasComponent:
[20:06:28][C][dallas.sensor:076]: Pin: GPIO5
[20:06:28][C][dallas.sensor:077]: Update Interval: 30.0s
[20:06:28][D][dallas.sensor:082]: Found sensors:
[20:06:28][D][dallas.sensor:084]: 0xd3062261522a4828
[20:06:28][D][dallas.sensor:084]: 0x42011447e180aa28
[20:06:28][D][dallas.sensor:084]: 0x6e0114480720aa28
[20:06:28][D][dallas.sensor:084]: 0xec0114482f52aa28
[20:06:28][D][dallas.sensor:084]: 0x3b01144865f6aa28
[20:06:28][D][dallas.sensor:084]: 0x4f0114488ed1aa28
[20:06:28][D][dallas.sensor:084]: 0x400114485219aa28
[20:06:28][D][dallas.sensor:084]: 0x770114478e3baa28
[20:06:28][D][dallas.sensor:084]: 0x8806226181a1fa28
[20:06:28][D][dallas.sensor:084]: 0xc00621946b139128
[20:06:28][D][dallas.sensor:084]: 0xcc0621946d64e928
[20:06:28][D][dallas.sensor:084]: 0xf00621945c000d28
[20:06:28][D][dallas.sensor:084]: 0x540621945c66ed28
[20:06:28][D][dallas.sensor:084]: 0xa306226168b38328
[20:06:28][D][dallas.sensor:084]: 0x0506226178652328
[20:06:28][C][dallas.sensor:089]: Device 'TrmBHXOut'
[20:06:28][C][dallas.sensor:089]: Device Class: 'temperature'
[20:06:28][C][dallas.sensor:089]: State Class: 'measurement'
[20:06:28][C][dallas.sensor:089]: Unit of Measurement: '°C'
[20:06:28][C][dallas.sensor:089]: Accuracy Decimals: 1
[20:06:28][V][dallas.sensor:089]: Unique ID: 'dallas-d3062261522a4828'
[20:06:28][C][dallas.sensor:097]: Address: 0xd3062261522a4828
[20:06:28][C][dallas.sensor:098]: Resolution: 12
[20:06:28][C][dallas.sensor:089]: Device 'TrmGrizt2'
[20:06:28][V][dallas.sensor:089]: Unique ID: 'dallas-42011447e180aa28'
[20:06:28][C][dallas.sensor:097]: Address: 0x42011447e180aa28
[20:06:28][C][dallas.sensor:089]: Device 'TrasaIsHP'
[20:06:28][V][dallas.sensor:089]: Unique ID: 'dallas-6e0114480720aa28'
[20:06:28][C][dallas.sensor:097]: Address: 0x6e0114480720aa28
[20:06:28][C][dallas.sensor:089]: Device 'GrindOUT'
[20:06:28][V][dallas.sensor:089]: Unique ID: 'dallas-ec0114482f52aa28'
[20:06:28][C][dallas.sensor:097]: Address: 0xec0114482f52aa28
[20:06:29][C][dallas.sensor:089]: Device 'SVprFiltr'
[20:06:29][C][dallas.sensor:089]: Device Class: 'temperature'
[20:06:29][C][dallas.sensor:089]: State Class: 'measurement'
[20:06:29][C][dallas.sensor:089]: Unit of Measurement: '°C'
[20:06:29][C][dallas.sensor:089]: Accuracy Decimals: 1
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-3b01144865f6aa28'
[20:06:29][C][dallas.sensor:097]: Address: 0x3b01144865f6aa28
[20:06:29][C][dallas.sensor:098]: Resolution: 12
[20:06:29][C][dallas.sensor:089]: Device 'RadOUT'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-4f0114488ed1aa28'
[20:06:29][C][dallas.sensor:097]: Address: 0x4f0114488ed1aa28
[20:06:29][C][dallas.sensor:089]: Device 'GrindIN'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-400114485219aa28'
[20:06:29][C][dallas.sensor:097]: Address: 0x400114485219aa28
[20:06:29][C][dallas.sensor:089]: Device 'SVprBHX'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-770114478e3baa28'
[20:06:29][C][dallas.sensor:097]: Address: 0x770114478e3baa28
[20:06:29][C][dallas.sensor:089]: Device 'KVpoBHX'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-8806226181a1fa28'
[20:06:29][C][dallas.sensor:097]: Address: 0x8806226181a1fa28
[20:06:29][C][dallas.sensor:089]: Device 'KViNama'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-c00621946b139128'
[20:06:29][C][dallas.sensor:097]: Address: 0xc00621946b139128
[20:06:29][C][dallas.sensor:089]: Device 'RadIN'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-cc0621946d64e928'
[20:06:29][C][dallas.sensor:097]: Address: 0xcc0621946d64e928
[20:06:29][C][dallas.sensor:089]: Device 'FankIN'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-f00621945c000d28'
[20:06:29][C][dallas.sensor:097]: Address: 0xf00621945c000d28
[20:06:29][C][dallas.sensor:089]: Device 'FankOUT'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-540621945c66ed28'
[20:06:29][C][dallas.sensor:097]: Address: 0x540621945c66ed28
[20:06:29][C][dallas.sensor:089]: Device 'SolarCol'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-a306226168b38328'
[20:06:29][C][dallas.sensor:097]: Address: 0xa306226168b38328
[20:06:29][C][dallas.sensor:089]: Device 'TrasaIHP'
[20:06:29][V][dallas.sensor:089]: Unique ID: 'dallas-0506226178652328'
[20:06:29][C][dallas.sensor:097]: Address: 0x0506226178652328
[20:06:32][VV][scheduler:226]: Running interval '' with interval=10000 last_execution=39454 (now=49455)
[20:06:35][VV][scheduler:226]: Running interval '' with interval=60000 last_execution=4294959441 (now=52146)
[20:06:37][VV][scheduler:226]: Running interval 'update' with interval=30000 last_execution=24032 (now=54033)
[20:06:37][VV][scheduler:032]: set_timeout(name='0xd3062261522a4828', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0x42011447e180aa28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0x6e0114480720aa28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0xec0114482f52aa28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0x3b01144865f6aa28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0x4f0114488ed1aa28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0x400114485219aa28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0x770114478e3baa28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0x8806226181a1fa28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0xc00621946b139128', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0xcc0621946d64e928', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0xf00621945c000d28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0x540621945c66ed28', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0xa306226168b38328', timeout=750)
[20:06:37][VV][scheduler:032]: set_timeout(name='0x0506226178652328', timeout=750)
[20:06:37][W][component:232]: Component dallas took a long time for an operation (102 ms).
[20:06:37][W][component:233]: Components should block for at most 30 ms.
[20:06:38][VV][scheduler:226]: Running timeout '0xd3062261522a4828' with interval=750 last_execution=54049 (now=54800)
[20:06:38][VV][dallas.sensor:254]: Scratch pad: 2D.02.4B.46.7F.FF.7F.10.85 (85)
[20:06:38][D][dallas.sensor:143]: 'TrmBHXOut': Got Temperature=34.8°C
[20:06:38][V][sensor:043]: 'TrmBHXOut': Received new state 34.812500
[20:06:38][D][sensor:094]: 'TrmBHXOut': Sending state 34.81250 °C with 1 decimals of accuracy
[20:06:38][V][json:038]: Attempting to allocate 512 bytes for JSON serialization
[20:06:38][V][json:058]: Size after shrink 76 bytes
[20:06:38][W][component:232]: Component dallas took a long time for an operation (60 ms).
[20:06:38][W][component:233]: Components should block for at most 30 ms.
[20:06:38][VV][scheduler:226]: Running timeout '0x42011447e180aa28' with interval=750 last_execution=54055 (now=54893)
[20:06:38][VV][dallas.sensor:254]: Scratch pad: 96.02.4B.46.7F.FF.7F.10.04 (04)
[20:06:38][D][dallas.sensor:143]: 'TrmGrizt2': Got Temperature=41.4°C
[20:06:38][V][sensor:043]: 'TrmGrizt2': Received new state 41.375000
[20:06:38][D][sensor:094]: 'TrmGrizt2': Sending state 41.37500 °C with 1 decimals of accuracy
[20:06:38][W][component:232]: Component dallas took a long time for an operation (55 ms).
[20:06:38][VV][scheduler:226]: Running timeout '0x6e0114480720aa28' with interval=750 last_execution=54064 (now=54893)
[20:06:38][VV][dallas.sensor:254]: Scratch pad: 19.03.4B.46.7F.FF.7F.10.51 (51)
[20:06:38][D][dallas.sensor:143]: 'TrasaIsHP': Got Temperature=49.6°C
[20:06:38][V][sensor:043]: 'TrasaIsHP': Received new state 49.562500
[20:06:38][D][sensor:094]: 'TrasaIsHP': Sending state 49.56250 °C with 1 decimals of accuracy
[20:06:38][W][component:232]: Component dallas took a long time for an operation (78 ms).
[20:06:38][VV][scheduler:226]: Running timeout '0xec0114482f52aa28' with interval=750 last_execution=54074 (now=54893)
[20:06:38][VV][dallas.sensor:254]: Scratch pad: 31.01.4B.46.7F.FF.7F.10.A9 (A9)
[20:06:38][D][dallas.sensor:143]: 'GrindOUT': Got Temperature=19.1°C
[20:06:38][V][sensor:043]: 'GrindOUT': Received new state 19.062500
[20:06:38][D][sensor:094]: 'GrindOUT': Sending state 19.06250 °C with 1 decimals of accuracy
[20:06:38][W][component:232]: Component dallas took a long time for an operation (51 ms).
[20:06:38][VV][scheduler:226]: Running timeout '0x3b01144865f6aa28' with interval=750 last_execution=54079 (now=54893)
[20:06:38][VV][dallas.sensor:254]: Scratch pad: A6.01.4B.46.7F.FF.7F.10.BF (BF)
[20:06:38][D][dallas.sensor:143]: 'SVprFiltr': Got Temperature=26.4°C
[20:06:38][V][sensor:043]: 'SVprFiltr': Received new state 26.375000
[20:06:38][D][sensor:094]: 'SVprFiltr': Sending state 26.37500 °C with 1 decimals of accuracy
[20:06:38][VV][scheduler:226]: Running timeout '0x4f0114488ed1aa28' with interval=750 last_execution=54084 (now=54893)
[20:06:38][VV][dallas.sensor:254]: Scratch pad: 38.01.4B.46.7F.FF.7F.10.C0 (C0)
[20:06:38][D][dallas.sensor:143]: 'RadOUT': Got Temperature=19.5°C
[20:06:38][V][sensor:043]: 'RadOUT': Received new state 19.500000
[20:06:38][D][sensor:094]: 'RadOUT': Sending state 19.50000 °C with 1 decimals of accuracy
[20:06:38][V][json:058]: Size after shrink 72 bytes
[20:06:38][W][component:232]: Component dallas took a long time for an operation (73 ms).
[20:06:38][VV][scheduler:226]: Running timeout '0x400114485219aa28' with interval=750 last_execution=54088 (now=54893)
[20:06:38][VV][dallas.sensor:254]: Scratch pad: D6.00.4B.46.7F.FF.7F.10.37 (37)
[20:06:38][D][dallas.sensor:143]: 'GrindIN': Got Temperature=13.4°C
[20:06:38][V][sensor:043]: 'GrindIN': Received new state 13.375000
[20:06:38][D][sensor:094]: 'GrindIN': Sending state 13.37500 °C with 1 decimals of accuracy
[20:06:38][W][component:232]: Component dallas took a long time for an operation (59 ms).
[20:06:38][VV][scheduler:226]: Running timeout '0x770114478e3baa28' with interval=750 last_execution=54093 (now=54893)
[20:06:38][VV][dallas.sensor:254]: Scratch pad: B7.02.4B.46.7F.FF.7F.10.EF (EF)
[20:06:38][D][dallas.sensor:143]: 'SVprBHX': Got Temperature=43.4°C
[20:06:38][V][sensor:043]: 'SVprBHX': Received new state 43.437500
[20:06:38][D][sensor:094]: 'SVprBHX': Sending state 43.43750 °C with 1 decimals of accuracy
[20:06:38][W][component:232]: Component dallas took a long time for an operation (71 ms).
[20:06:38][VV][scheduler:226]: Running timeout '0x8806226181a1fa28' with interval=750 last_execution=54098 (now=54893)
[20:06:38][VV][dallas.sensor:254]: Scratch pad: BA.02.4B.46.7F.FF.7F.10.93 (93)
[20:06:38][D][dallas.sensor:143]: 'KVpoBHX': Got Temperature=43.6°C
[20:06:38][V][sensor:043]: 'KVpoBHX': Received new state 43.625000
[20:06:39][D][sensor:094]: 'KVpoBHX': Sending state 43.62500 °C with 1 decimals of accuracy
[20:06:39][V][json:038]: Attempting to allocate 512 bytes for JSON serialization
[20:06:39][V][json:058]: Size after shrink 72 bytes
[20:06:39][W][component:232]: Component dallas took a long time for an operation (60 ms).
[20:06:39][W][component:233]: Components should block for at most 30 ms.
[20:06:39][VV][scheduler:226]: Running timeout '0xc00621946b139128' with interval=750 last_execution=54103 (now=54893)
[20:06:39][VV][dallas.sensor:254]: Scratch pad: 6E.01.4B.46.7F.FF.7F.10.4E (4E)
[20:06:39][D][dallas.sensor:143]: 'KViNama': Got Temperature=22.9°C
[20:06:39][V][sensor:043]: 'KViNama': Received new state 22.875000
[20:06:39][D][sensor:094]: 'KViNama': Sending state 22.87500 °C with 1 decimals of accuracy
[20:06:39][W][component:232]: Component dallas took a long time for an operation (77 ms).
[20:06:39][VV][scheduler:226]: Running timeout '0xcc0621946d64e928' with interval=750 last_execution=54108 (now=54893)
[20:06:39][VV][dallas.sensor:254]: Scratch pad: 64.01.4B.46.7F.FF.7F.10.E2 (E2)
[20:06:39][D][dallas.sensor:143]: 'RadIN': Got Temperature=22.2°C
[20:06:39][V][sensor:043]: 'RadIN': Received new state 22.250000
[20:06:39][D][sensor:094]: 'RadIN': Sending state 22.25000 °C with 1 decimals of accuracy
[20:06:39][W][component:232]: Component dallas took a long time for an operation (55 ms).
[20:06:39][VV][scheduler:226]: Running timeout '0xf00621945c000d28' with interval=750 last_execution=54128 (now=54893)
[20:06:39][VV][dallas.sensor:254]: Scratch pad: B5.00.4B.46.7F.FF.7F.10.13 (13)
[20:06:39][D][dallas.sensor:143]: 'FankIN': Got Temperature=11.3°C
[20:06:39][V][sensor:043]: 'FankIN': Received new state 11.312500
[20:06:39][D][sensor:094]: 'FankIN': Sending state 11.31250 °C with 1 decimals of accuracy
[20:06:39][VV][scheduler:226]: Running timeout '0x540621945c66ed28' with interval=750 last_execution=54133 (now=54893)
[20:06:39][VV][dallas.sensor:254]: Scratch pad: B4.02.4B.46.7F.FF.7F.10.2A (2A)
[20:06:39][D][dallas.sensor:143]: 'FankOUT': Got Temperature=43.2°C
[20:06:39][V][sensor:043]: 'FankOUT': Received new state 43.250000
[20:06:39][D][sensor:094]: 'FankOUT': Sending state 43.25000 °C with 1 decimals of accuracy
[20:06:39][W][component:232]: Component dallas took a long time for an operation (61 ms).
[20:06:39][VV][scheduler:226]: Running timeout '0xa306226168b38328' with interval=750 last_execution=54138 (now=54893)
[20:06:39][VV][dallas.sensor:254]: Scratch pad: 4F.02.4B.46.7F.FF.7F.10.E2 (E2)
[20:06:39][D][dallas.sensor:143]: 'SolarCol': Got Temperature=36.9°C
[20:06:39][V][sensor:043]: 'SolarCol': Received new state 36.937500
[20:06:39][D][sensor:094]: 'SolarCol': Sending state 36.93750 °C with 1 decimals of accuracy
[20:06:39][V][json:058]: Size after shrink 76 bytes
[20:06:39][VV][scheduler:226]: Running timeout '0x0506226178652328' with interval=750 last_execution=54143 (now=54893)
[20:06:39][VV][dallas.sensor:254]: Scratch pad: 4A.01.4B.46.7F.FF.7F.10.F3 (F3)
[20:06:39][D][dallas.sensor:143]: 'TrasaIHP': Got Temperature=20.6°C
[20:06:39][V][sensor:043]: 'TrasaIHP': Received new state 20.625000
[20:06:39][D][sensor:094]: 'TrasaIHP': Sending state 20.62500 °C with 1 decimals of accuracy
[20:06:39][VV][scheduler:226]: Running interval 'update' with interval=30000 last_execution=26193 (now=56197)
[20:06:39][W][dallas:165]: Warning cleared
[20:06:39][E][dallas.sensor:112]: Requesting conversion failed
[20:06:39][W][dallas:152]: Warning set: unspecified
[20:06:42][VV][scheduler:226]: Running interval '' with interval=10000 last_execution=49454 (now=59455)
[20:06:52][VV][scheduler:226]: Running interval '' with interval=10000 last_execution=59454 (now=69455)
