I’m completely loosing my mind here …
I have a fastLED strip sucessfully configured and partitioned (into 14 parts) and am now trying to create two template switches, which should turn them on (and off) with delays from either sides…
only If I just create one template switch it works … as soon as I try to make a second template switch, the file won’t upload wirelessly to the Sonoff Basic. When I try to manually upload it, it works but results in a bootloop of the Sonoff…
Here’s my complete yaml:
esphome:
platform: ESP8266
board: esp8285
substitutions:
device_name: stiegenaufgang-treppe
friendly_name: Stiegenaufgang Treppe
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_pass
# ap:
# ssid: "${device_name} wifi"
# password: "xxx"
logger:
#level: INFO
# Enable Home Assistant API
api:
password: !secret api_ota_pass
ota:
text_sensor:
- platform: version
hide_timestamp: true
name: "${friendly_name} - ESPHome Version"
- platform: wifi_info
ip_address:
name: "${friendly_name} - IP Address"
icon: mdi:wifi
ssid:
name: "${friendly_name} - Connected SSID"
icon: mdi:wifi-strength-2
# Sensors with general information.
# Uptime sensor.
- platform: uptime
# WiFi Signal sensor.
- platform: wifi_signal
name: "${friendly_name} WiFi Signal"
update_interval: 60s
- platform: homeassistant
entity_id: input_number.treppe_brightness
entity_id: input_number.treppe_transition
entity_id: input_number.treppe_delay
entity_id: input_number.treppe_red
entity_id: input_number.treppe_green
entity_id: input_number.treppe_blue
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "${friendly_name} - Button Internal"
on_press:
- if:
condition:
switch.is_off: relay
then:
- switch.toggle: relay
- delay: 50ms
- light.turn_on: led_all
else:
- light.turn_off: led_all
- delay: 3s
status_led:
pin:
number: GPIO13
inverted: yes
switch:
- platform: gpio
pin: GPIO12
# after reboot, keep the relay off. this prevents light turning on after a power outage
restore_mode: ALWAYS_OFF
turn_on_action:
- script.execute: vu_on
turn_off_action:
- script.execute: vu_off
turn_on_action:
- script.execute: vo_on
turn_off_action:
- script.execute: vo_off
script:
- id: vu_on
then:
- switch.turn_on: relay
- delay: 50ms
- light.turn_on:
transition_length: !lambda 'return id(treppe_transition).state;'
brightness: !lambda 'return id(treppe_brightness).state;'
red: !lambda 'return id(treppe_red).state;'
green: !lambda 'return id(treppe_green).state;'
blue: !lambda 'return id(treppe_blue).state;'
- delay: !lambda 'return id(treppe_delay).state;'
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- id: vu_off
then:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- delay: 250ms
- switch.turn_off: relay
- id: vo_on
then:
- delay: 50ms
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- id: vo_off
then:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- delay: 250ms
light:
- platform: fastled_clockless
chipset: WS2811
pin: GPIO14
num_leds: 100
rgb_order: BRG
name: "FastLED WS2811 Light"
# You may want (but don't need) this:
internal: true
- platform: partition
segments:
# Use first 9 LEDs from the light with ID ledstrip
- id: ledstrip
to: 99
effects:
# Use default parameters:
- addressable_rainbow:
- addressable_scan:
- addressable_twinkle:
- addressable_random_twinkle:
- addressable_color_wipe:
- addressable_fireworks:
- addressable_flicker:
- pulse:
- strobe:
- flicker:
segments:
- id: ledstrip
to: 8
segments:
- id: ledstrip
to: 15
segments:
- id: ledstrip
to: 22
segments:
- id: ledstrip
to: 29
segments:
- id: ledstrip
to: 36
segments:
- id: ledstrip
to: 43
segments:
- id: ledstrip
to: 50
segments:
- id: ledstrip
to: 57
segments:
- id: ledstrip
to: 64
segments:
- id: ledstrip
to: 71
segments:
- id: ledstrip
to: 78
segments:
- id: ledstrip
to: 85
segments:
- id: ledstrip
to: 92
segments:
- id: ledstrip
to: 99
I also tried to just put the scripts into the template switch … it also only works as long as there is just one switch … as soon as I add another one, it doesn’t
like that:
switch:
turn_on_action:
- delay: 50ms
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
- light.turn_on:
turn_off_action:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- light.turn_off:
- delay: 250ms
What am I doing wrong?!
