I’m new to home automation and very excited about it and still trying to get my head around it all.
I’ve watched countless numbers of videos to help teach myself but still have a few things I dont understand and would very much appreciate any help setting up my first Automation with the Sonoff TH16 switch.
So far I have:
Installed Hassio on RPi3B+
Successfully flashed the SonoffTH
Set up MQTT Mosquito on Hassio
Successfully used “discovery” to find the SonoffTH in Hassio (not sure if discover is the best option for entities?)
The Temperature is visible in Hassio
The switch works and can be toggled in Hassio
I am trying to create an automation that will:
Turn on the switch at 08:00
Turn off the switch at 10:00
Turn on the switch at 16:00
Turn off the switch at 18:00
This automation needs to run daily
I also need:
A toggle that I can use to manually turn on the switch and it will stay on until I manually turn the toggle off
I have googled everything, but am having a hard time with the sensor.time (not even sure if I should be using this?)
I can set a specific time and activate the switch, but can not figure out how to do the rest.
My Sonoff TH details are as follows: switch.spa sensor.sonoff_ds18b20_temperature
Write four automations of this format to turn on and off at the required times. The condition check of the state of the input_boolean is your manual override.
- id: on_at_0800
alias: 'On at 08:00'
platform: time
at: '08:00:00'
condition:
condition: state ### only if the override switch is off (you really only need this condition block in the 'off' automations.)
entity_id: input_boolean.override_switch
state: 'off'
service: switch.turn_on
entity_id: switch.your_sonoff_switch_id_here
And one automation to turn the switch on with the override input boolean:
- id: switch_override
alias: 'Switch Override'
platform: state
to: 'on'
Your ‘override’ input_boolean should look something like this:
override_switch:
icon: mdi:power ### choose whatever you want from the 'material design icons' web page.
Thank you so much @tom_l for your help. I really appreciate it!
This is fantastic support!!
I’m going to work on this shortly.
I’ll let you know how I go.
just wanted to say thanks again @tom_l for your support.
it worked like a treat.
I have also disabled “discovery” of MQTT entities and have learnt how to add them manually.
