Some notification platforms (XMPP, Telegram…) are sending messages through IM platforms. It feels tempting to answer to the notifications.
The use case I have currently is the following: I send notifications via XMPP if I’m at work, from 16:30 to 20:00, every time a bus is 10 minutes away. Sometimes (like today), I go to work by car, or I know I won’t leave until later. Disabling the notifications for a while, turning a switch on/off… directly from XMPP would be awesome.
Have an Android device? You could probably accomplish this with the HTML5 notification platform.
Or you could bypass entirely and set up a IFTTT with maker channel to toggle an input boolean on or off and then have your notifications test for the boolean to be on before a message is sent.
I receive the XMPP messages on multiple devices. While I’m at the office, I’m mostly using the default IM client on my Mac (I don’t know how it’s called, Messages?)
I already have an input boolean to disable the notifications. What I would like to see is a way to interact with this input boolean from XMPP.
