tydom2MQTT addon :D - Delta Dore Tydom to MQTT Broker
New release add climate managment thx to gus8313 ! Test time guys !
trying with my thermostats seem not working
Tydom Client is connected to websocket and ready !
Requesting 1st data...
>>>>>>>>>> Sending to tydom client..... GET /info
>>>>>>>>>> Sending to tydom client..... POST /refresh/all
>>>>>>>>>> Sending to tydom client..... GET /configs/file
>>>>>>>>>> Sending to tydom client..... GET /devices/data
<<<<<<<<<< Receiving from tydom_client...
Incoming message type : Info detected
Incoming data parsed successfully !
Incoming message type : data detected
Cannot parse response !
Error :  string indices must be integers
{'version': '1.0.1', 'moments': [], 'id_catalog': 'F2BD90F93B888DA02C54980F11AE4796DFCC98F447CD3FE326F5A3A964C939BF', 'areas': [], 'endpoints': [{'last_usage': 'window', 'id_device': 1589883539, 'anticipation_start': False, 'id_endpoint': 1589883539, 'name': 'Bureau droite', 'first_usage': 'window', 'picto': 'picto_window'}, {'first_usage': 'window', 'picto': 'picto_window', 'last_usage': 'windowFrench', 'anticipation_start': False, 'name': 'Bureau gauche', 'id_device': 1589883713, 'id_endpoint': 1589883713}, {'id_endpoint': 1589883816, 'picto': 'picto_window', 'anticipation_start': False, 'last_usage': 'windowFrench', 'id_device': 1589883816, 'name': 'Salle de bain', 'first_usage': 'window'}, {'last_usage': 'window', 'first_usage': 'window', 'anticipation_start': False, 'id_endpoint': 1589883930, 'id_device': 1589883930, 'picto': 'picto_window', 'name': 'Chambre Constance'}, {'picto': 'picto_window', 'anticipation_start': False, 'last_usage': 'windowFrench', 'id_endpoint': 1590827319, 'name': 'Détecteur 2', 'first_usage': 'window', 'id_device': 1590827319}, {'last_usage': 'windowFrench', 'id_endpoint': 1589884607, 'picto': 'picto_window', 'first_usage': 'window', 'anticipation_start': False, 'name': 'WC', 'id_device': 1589884607}, {'first_usage': 'window', 'anticipation_start': False, 'id_endpoint': 1589884784, 'picto': 'picto_window', 'name': 'Cuisine', 'id_device': 1589884784, 'last_usage': 'windowFrench'}, {'first_usage': 'window', 'last_usage': 'window', 'id_endpoint': 1590779132, 'picto': 'picto_window_lock', 'name': 'Détecteur 1', 'id_device': 1590779132, 'anticipation_start': False}, {'last_usage': 'window', 'name': 'Salon gauche', 'picto': 'picto_window', 'id_device': 1589885658, 'first_usage': 'window', 'id_endpoint': 1589885658, 'anticipation_start': False}, {'picto': 'picto_window', 'anticipation_start': False, 'id_endpoint': 1589885757, 'last_usage': 'window', 'id_device': 1589885757, 'name': 'Salon droit', 'first_usage': 'window'}, {'last_usage': 'window', 'first_usage': 'window', 'id_device': 1589885896, 'name': 'Baie nord', 'anticipation_start': False, 'picto': 'picto_window', 'id_endpoint': 1589885896}, {'picto': 'picto_window', 'id_endpoint': 1589886026, 'first_usage': 'window', 'id_device': 1589886026, 'anticipation_start': False, 'last_usage': 'window', 'name': 'Baie est gauche'}, {'picto': 'picto_window', 'first_usage': 'window', 'id_device': 1589886161, 'id_endpoint': 1589886161, 'anticipation_start': False, 'last_usage': 'window', 'name': 'Baie est droite'}, {'id_endpoint': 1604820544, 'id_device': 1604820544, 'picto': 'picto_belmdoor', 'name': 'Porte Chambre Parent', 'anticipation_start': False, 'first_usage': 'belmDoor', 'last_usage': 'belmDoor'}, {'first_usage': 'hvac', 'id_endpoint': 1605799383, 'id_device': 1605799383, 'name': 'Chauffage RDC', 'picto': 'picto_thermometer', 'last_usage': 'boiler', 'anticipation_start': False}, {'anticipation_start': False, 'id_device': 1605799482, 'last_usage': 'boiler', 'picto': 'picto_thermometer', 'name': 'Chauffage Etage', 'first_usage': 'hvac', 'id_endpoint': 1605799482}, {'picto': 'picto_thermometer', 'name': 'Chauffage Ch Amis', 'first_usage': 'hvac', 'anticipation_start': False, 'id_endpoint': 1605799540, 'id_device': 1605799540, 'last_usage': 'boiler'}], 'groups': [{'usage': 'window', 'group_all': False, 'id': 1293446020, 'picto': 'picto_window', 'name': 'Baie Est Droite'}, {'usage': 'window', 'picto': 'picto_window', 'id': 910283753, 'name': 'Baie Est Gauche', 'group_all': False}, {'picto': 'picto_window', 'id': 575301829, 'group_all': False, 'name': 'Baie Nord', 'usage': 'window'}, {'name': 'TOTAL', 'usage': 'light', 'group_all': True, 'id': 1668318474, 'picto': 'picto_lamp'}, {'id': 258981127, 'picto': 'picto_shutter', 'group_all': True, 'usage': 'shutter', 'name': 'TOTAL'}, {'id': 1865462383, 'usage': 'awning', 'name': 'TOTAL', 'group_all': True, 'picto': 'picto_awning_awning'}, {'id': 716588285, 'usage': 'window', 'picto': 'picto_window', 'name': 'Bureau Droite', 'group_all': False}, {'usage': 'window', 'name': 'Bureau Gauche', 'group_all': False, 'widget_behavior': {'inversionState': 'disabled'}, 'picto': 'picto_window', 'id': 1980812653}, {'group_all': False, 'picto': 'picto_window', 'name': 'Salle de bain', 'id': 455540512, 'usage': 'window'}, {'usage': 'window', 'id': 1982748604, 'picto': 'picto_window', 'group_all': False, 'name': 'Chambre Constance'}, {'picto': 'picto_window', 'usage': 'window', 'name': 'WC', 'group_all': False, 'widget_behavior': {'inversionState': 'disabled'}, 'id': 1165069053}, {'id': 570421109, 'picto': 'picto_window', 'usage': 'window', 'name': 'Cuisine', 'group_all': False}, {'id': 1020521302, 'name': 'Salon droit', 'picto': 'picto_window', 'group_all': False, 'usage': 'window'}, {'group_all': False, 'id': 1245751637, 'name': 'Salon gauche', 'picto': 'picto_window', 'usage': 'window'}], 'scenarios': [], 'old_tycam': False, 'os': 'ios', 'date': 1605799586, 'version_application': '3.10.1 (345)'}
msg_data error in parsing !
1605799383
1605799482
1605799540
1589883539
1589883713
1589883816
1589883930
1589884607
1589884784
1589885658
1589885757
1589885896
1589886026
1589886161
1590779132
1590827319
1604820544
1605799383
1605799482
1605799540
1605799383
I also try running Tydom2mqtt and I’m new to HA…
In the log for Tydom2mqtt, I have an error about parsing at line 1 :
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: Tydom2MQTT - Beta
 Link between a Delta Dore's Tydom 1.0 Hub and and a MQTT broker, unofficial of course, hassio addon version
 Add-on version: release_0.96a
 You are running the latest version of this add-on.
parse error: Expected string key before ':' at line 1, column 4
[21:22:12] ERROR: Unknown HTTP error occured
 System:   (amd64 / intel-nuc)
 Home Assistant Core: 0.118.0
 Home Assistant Supervisor: 2020.11.0
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Starting /opt/tydom2mqtt/main.py
But In the mosquitto broker I have :
1605820934: New client connected from 172.30.32.1 as 70812686-tydom2mqtt-hassio2020-11-19 21:22:14.555287 (p5, c1, k60, u'mqtt-utilisateur').
So I suppose that the mqtt is working in someway ? But I don’t know what to do next…
Thanks for your help.
I have roller shutters controlled by Tydom 1.0 and I would like to connect it to my Hassio box, I have installed the plugin by HACS and I have injected the connection command line to my config file (mac. ip and password ). I tried with mqtt to explore to have the info feedback but I have nothing and the same thing with the mqtt of my hassio. Do you have a solution ?
hi @WiwiWillou,
Can you update your repository seem this file has not been updated
Always pointing to the 0.93 version can you update with the latest 0.96a
Thanks @fransiouz for the last release with the climate.
Now i can manage my Doors/Windows Sensor (DVI) and Climate DeltaDore with success !!!
I’ve this message in the Tydom log
1572979358
all my covers are working, but can’t find my door opening sensor in my entities.
Can it be it ?
How do you install it on Home assistant
someone can put a screenshot of how it is represented in HA ?
By the way, I’ve got the same error as Cadaver
what did you put as config because I have nothing which goes back to Mqtt. mac full address or the first 6?
I installed with the repo in supervisor addon store, and I’ve put the full adress MAC of my tybox.
As I said on my previous post, the repo of @WiwiWillou is not pointing to the latest version available.
If you want to try with the latest version, add my repo and test:
Ok but when I look in your repo, I see version release_0.96b as the wiwiwillou repo. Is it any difference betwen this 2 versions ?
Yes, when you install from the wiwiwillou repo it’s download and install this version 0.93.
Yes but system ask me for an update and now I’m in 0.96b
it’s only a label but the version installed is 0.93, try the same version on my repo, you will see the difference
Now I’ve this error : image
Edit : After a while it start !
you’re right, I see now more sensor with your version and didn’t have the error message anymore. tks a lot. Anyway I don’t see my door sensor appear.
which type of door sensor do you have?
i have one door sensor (dvi) and 13 windows sensor (dvi) working fine
I’ve a MDO Tyxal+ for a interior door.
