tydom2MQTT addon :D - Delta Dore Tydom to MQTT Broker
Hi and welcome !
1st check if MQTT is working by going to Dev tools, listen # (you can test too with a message in Dev tools in home assistant and listening to your MQTT broker).
2nd I need more logs on the tydom part if it’s not working (check GitHub use python version of you and open an issue).
Note : any other tydom 2 users here ? I have tydom 1 so it might be the reason data is not parsed correctly (or it can be a minor thing and just MQTT that is not working :wink:
You have added MQTT integration in home assistant ?
Thanks for your feedback.
1st : yep, my MQTT seems to work. I can listen # and if I send a command, it get a feedback.
2nd : I tried to install docker but I get “docker: invalid reference format.”
And with python version, not better…
python3.7 main.py
  File "main.py", line 301, in <module>
    asyncio.get_event_loop().run_until_complete(main_task())
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/asyncio/base_events.py", line 584, in run_until_complete
    return future.result()
  File "main.py", line 256, in main_task
    conn.request("GET", "/mediation/client?mac={}&appli=1".format(mac), None, httpHeaders)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/http/client.py", line 1229, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/http/client.py", line 1275, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/http/client.py", line 1224, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/http/client.py", line 1016, in _send_output
    self.send(msg)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/http/client.py", line 956, in send
    self.connect()
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/http/client.py", line 1384, in connect
    super().connect()
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/http/client.py", line 928, in connect
    (self.host,self.port), self.timeout, self.source_address)
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/socket.py", line 727, in create_connection
    raise err
  File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/socket.py", line 716, in create_connection
    sock.connect(sa)
TimeoutError: [Errno 60] Operation timed out
I think I’m doing something wrong :sweat:
Hi again,
I succeed to execute python script from your other post : Tydom2mqtt - Make Delta Dore devices home assistant compatible ! =}
Result is my MQTT connexion is working using mqttconnection function.
This is the http connection to my TYDOM 2.0 that fail into timeout.
How can I investigate what is going wrong and/or how can I find the parameters send from TYDOM app to tydom 2.0 ?
Thanks for your help and advices
Me again…!
@WiwiWillou : are you able to give me the raw curl to execute in order to get Tydom response ?
Like this :
curl --location --request GET 'https://HOST:443/mediation/client?mac=TYDOM_MAC&appli=1' \
--header 'Upgrade: websocket' \
--header 'Connection: Upgrade' \
--header 'host: HOST:443' \
--header 'Accept: */*' \
--header 'Sec-WebSocket-Key: meP5gVDx7/SXq7Qo1t6Yrg==' \
--header 'Sec-WebSocket-Version: 13'
For the websocket key it’s an example generate from your function generate_random_key()
I would like to test through postman directly and see the result.
Maybe I miss some other header or params… But when I execute this, I get a timeout.
Thanks for your support !
Mmh i can’t really help from here, i just copied the connection code from an old repo : https://github.com/cth35/tydom_python
Did you try with the remote connection ? (mediation.tydom.com)
in my code :
    async def connect(self):
        print('""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""')
        print('TYDOM WEBSOCKET CONNECTION INITIALISING....                     ')
        print('Building headers, getting 1st handshake and authentication....')
        httpHeaders =  {"Connection": "Upgrade",
                        "Upgrade": "websocket",
                        "Host": self.host + ":443",
                        "Accept": "*/*",
                        "Sec-WebSocket-Key": self.generate_random_key(),
                        "Sec-WebSocket-Version": "13"
        conn = http.client.HTTPSConnection(self.host, 443, context=self.ssl_context)
        # Get first handshake
        conn.request("GET", "/mediation/client?mac={}&appli=1".format(self.mac), None, httpHeaders)
        res = conn.getresponse()
        # Get authentication
        nonce = res.headers["WWW-Authenticate"].split(',', 3)
        # read response
        res.read()
        # Close HTTPS Connection
        conn.close()
        print('Upgrading http connection to websocket....')
        # Build websocket headers
        websocketHeaders = {'Authorization': self.build_digest_headers(nonce)}
        if self.ssl_context is not None:
            websocket_ssl_context = self.ssl_context
        else:
            websocket_ssl_context = True # Verify certificate
    # outer loop restarted every time the connection fails
        print('Attempting websocket connection with tydom hub.......................')
        print('Host Target :')
        print(self.host)
            Connecting to webSocket server
            websockets.client.connect returns a WebSocketClientProtocol, which is used to send and receive messages
        self.connection = await websockets.client.connect('wss://{}:443/mediation/client?mac={}&appli=1'.format(self.host, self.mac),
                                                            extra_headers=websocketHeaders, ssl=websocket_ssl_context, ping_timeout=None)
        return self.connection
Hi, After the update with the last version, here is my error, i use Tydom 1.0 with door sensor and climate
Host Target :
192.168.1.5
Tydom Client is connected to websocket and ready !
Requesting 1st data...
>>>>>>>>>> Sending to tydom client..... GET /info
>>>>>>>>>> Sending to tydom client..... POST /refresh/all
>>>>>>>>>> Sending to tydom client..... GET /configs/file
>>>>>>>>>> Sending to tydom client..... GET /devices/data
<<<<<<<<<< Receiving from tydom_client...
Incoming message type : Info detected
Incoming data parsed successfully !
Incoming message type : data detected
Cannot parse response !
Error :  string indices must be integers
{'id_catalog': 'F2BD90F93B888DA02C54980F11AE4796DFCC98F447CD3FE326F5A3A964C939BF', 'os': 'ios', 'groups': [{'usage': 'window', 'picto': 'picto_window', 'group_all': False, 'id': 1293446020, 'name': 'Baie Est Droite'}, {'picto': 'picto_window', 'name': 'Baie Est Gauche', 'usage': 'window', 'id': 910283753, 'group_all': False}, {'usage': 'window', 'name': 'Baie Nord', 'picto': 'picto_window', 'id': 575301829, 'group_all': False}, {'name': 'TOTAL', 'picto': 'picto_lamp', 'usage': 'light', 'group_all': True, 'id': 1668318474}, {'name': 'TOTAL', 'id': 258981127, 'usage': 'shutter', 'picto': 'picto_shutter', 'group_all': True}, {'name': 'TOTAL', 'picto': 'picto_awning_awning', 'id': 1865462383, 'usage': 'awning', 'group_all': True}, {'name': 'Bureau Droite', 'picto': 'picto_window', 'id': 716588285, 'group_all': False, 'usage': 'window'}, {'usage': 'window', 'group_all': False, 'widget_behavior': {'inversionState': 'disabled'}, 'name': 'Bureau Gauche', 'id': 1980812653, 'picto': 'picto_window'}, {'picto': 'picto_window', 'usage': 'window', 'id': 455540512, 'group_all': False, 'name': 'Salle de bain'}, {'picto': 'picto_window', 'group_all': False, 'usage': 'window', 'id': 1982748604, 'name': 'Chambre Constance'}, {'name': 'WC', 'picto': 'picto_window', 'usage': 'window', 'id': 1165069053, 'group_all': False, 'widget_behavior': {'inversionState': 'disabled'}}, {'usage': 'window', 'id': 570421109, 'name': 'Cuisine', 'picto': 'picto_window', 'group_all': False}, {'group_all': False, 'picto': 'picto_window', 'id': 1640813503, 'name': 'Chambre Charlotte', 'usage': 'window'}, {'id': 1245751637, 'name': 'Salon gauche', 'usage': 'window', 'picto': 'picto_window', 'group_all': False}, {'name': 'Salon droit', 'picto': 'picto_window', 'group_all': False, 'id': 1020521302, 'usage': 'window'}, {'name': 'Chambre amis droite', 'usage': 'window', 'group_all': False, 'id': 12139290, 'picto': 'picto_window'}], 'scenarios': [], 'version_application': '3.10.0 (323)', 'areas': [], 'version': '1.0.1', 'date': 1601913550, 'endpoints': [{'id_device': 1589883539, 'picto': 'picto_window', 'name': 'Battant droit ', 'anticipation_start': False, 'last_usage': 'window', 'id_endpoint': 1589883539, 'first_usage': 'window'}, {'id_device': 1589883713, 'anticipation_start': False, 'picto': 'picto_window', 'id_endpoint': 1589883713, 'first_usage': 'window', 'name': 'Battant gauche', 'last_usage': 'windowFrench'}, {'name': 'CG_DD_USAGE_WINDOWFRENCH_NEW 2', 'id_endpoint': 1589883816, 'picto': 'picto_window', 'anticipation_start': False, 'first_usage': 'window', 'last_usage': 'windowFrench', 'id_device': 1589883816}, {'first_usage': 'window', 'last_usage': 'window', 'id_device': 1589883930, 'id_endpoint': 1589883930, 'name': 'Fenêtre ', 'picto': 'picto_window', 'anticipation_start': False}, {'first_usage': 'hvac', 'last_usage': 'boiler', 'id_endpoint': 1589902721, 'picto': 'picto_thermometer', 'name': 'Séjour', 'id_device': 1589902721, 'anticipation_start': False}, {'picto': 'picto_window', 'first_usage': 'window', 'id_device': 1589884607, 'anticipation_start': False, 'last_usage': 'windowFrench', 'name': 'WC', 'id_endpoint': 1589884607}, {'id_device': 1589884784, 'picto': 'picto_window', 'name': 'Battant droit', 'first_usage': 'window', 'anticipation_start': False, 'id_endpoint': 1589884784, 'last_usage': 'windowFrench'}, {'picto': 'picto_window', 'first_usage': 'window', 'last_usage': 'windowFrench', 'name': 'Battant gauche ', 'id_endpoint': 1590779132, 'anticipation_start': False, 'id_device': 1590779132}, {'first_usage': 'window', 'last_usage': 'window', 'anticipation_start': False, 'id_endpoint': 1589885658, 'id_device': 1589885658, 'name': 'Battant droit', 'picto': 'picto_window'}, {'first_usage': 'window', 'last_usage': 'window', 'anticipation_start': False, 'name': 'Battant droit', 'picto': 'picto_window', 'id_endpoint': 1589885757, 'id_device': 1589885757}, {'last_usage': 'window', 'id_device': 1589885896, 'picto': 'picto_window', 'name': 'Battant droit', 'anticipation_start': False, 'id_endpoint': 1589885896, 'first_usage': 'window'}, {'picto': 'picto_window', 'anticipation_start': False, 'name': 'Battant gauche', 'last_usage': 'window', 'id_device': 1589886026, 'first_usage': 'window', 'id_endpoint': 1589886026}, {'id_device': 1589886161, 'picto': 'picto_window', 'anticipation_start': False, 'id_endpoint': 1589886161, 'first_usage': 'window', 'name': 'Battant droit', 'last_usage': 'window'}, {'id_device': 1589902483, 'name': 'Chambre d’amis', 'first_usage': 'hvac', 'picto': 'picto_thermometer', 'id_endpoint': 1589902483, 'last_usage': 'boiler', 'anticipation_start': False}, {'id_device': 1589902673, 'name': 'Etage', 'last_usage': 'boiler', 'id_endpoint': 1589902673, 'first_usage': 'hvac', 'anticipation_start': False, 'picto': 'picto_thermometer'}, {'name': 'Porte ', 'id_device': 1590768079, 'anticipation_start': False, 'picto': 'picto_belmdoor', 'last_usage': 'belmDoor', 'first_usage': 'belmDoor', 'id_endpoint': 1590768079}, {'first_usage': 'window', 'name': 'Battant droit', 'id_endpoint': 1590827319, 'anticipation_start': False, 'picto': 'picto_window', 'last_usage': 'windowFrench', 'id_device': 1590827319}], 'moments': [], 'old_tycam': False}
msg_data error in parsing !
1589883539
1589883816
1589883930
1589884607
1589884784
1589885658
1589885757
1589885896
1589886026
1589886161
1589902483
1589902673
1589902721
1590768079
1590779132
1590827319
1589902483
Hi, I don’t have the devices at home, could you please try to start the python script ? To pinpoint the line where the error is…
And just to know, does the others devices types work even with the error ?
hi,
i have only 14 doors detector and 3 thermostats, so all are not working unfortunately, checking in parallel with bbo76 for debuging
First : thanks a lot for all the effort put in this addon :slight_smile:
I am new to HASS and tried to install the tydom2mqtt addon so that I can play around with my X3D equipments :smiley:
For now I have installed HASS on a raspberry pi 4. I have installed the MQTT and the Mosquitto broker addon. Then I have installed the tydom2mqtt addon and modified the TYDOM_MAC, TYDOM_IP and TYDOM_PASSWORD in the configuration tab .
I have also modified the mqtt properties, with :
MQTT_HOST: localhost
MQTT_USER: mosquitto #(user I have created in HASSIO configuration/users menu)
MQTT_PASSWORD: xxxxxx
(I left the other properties unchanged)
But I’ve got an error when I restart the addon (see below).
I am sure I have missed something in my setup but I don’t know what or where to look :frowning:
So if someone can help me :smiley:
My logs :
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Tydom2MQTT - Beta
Link between a Delta Dore's Tydom 1.0 Hub and and a MQTT broker, unofficial of course, hassio addon version
 Add-on version: release_0.94b
 You are running the latest version of this add-on.
parse error: Expected string key before ':' at line 1, column 4
[17:03:50] ERROR: Unknown HTTP error occured
 System:   (armv7 / raspberrypi4)
 Home Assistant Core: 0.117.2
 Home Assistant Supervisor: 2020.10.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Starting /opt/tydom2mqtt/main.py
then a few seconds later :
1604425191: Socket error on client <unknown>, disconnecting.
1604425198: New connection from 172.30.32.1 on port 1883.
[INFO] found mosquitto on local database
1604425198: New client connected from 172.30.32.1 as 63fe4315-tydom2mqtt-hassio2020-11-03 18:39:58.180843 (p5, c1, k60, u'mosquitto').
1604425246: Socket error on client 63fe4315-tydom2mqtt-hassio2020-11-03 18:39:58.180843, disconnecting.
1604425253: New connection from 172.30.32.1 on port 1883.
1604425253: New client connected from 172.30.32.1 as 63fe4315-tydom2mqtt-hassio2020-11-03 18:40:53.005635 (p5, c1, k60, u'mosquitto').
1604425368: Socket error on client 63fe4315-tydom2mqtt-hassio2020-11-03 18:40:53.005635, disconnecting.
1604425372: New connection from 172.30.32.1 on port 1883.
[ERROR] Auth error with mqtt_user
EDIT :
after several minutes I get these messages in the logs :
1541154049
So something good is happening :smile: but don’t know what I should do next…
Yes, i tried both local IP and mediation.tydom.com.
I succeed also to launch docker image with the rights parameters (without passing through HASSIO) and the result is quite the same than @tonioa
Host Target :
mediation.tydom.com
MY JSON (do you need it ???)
1590338188
JSON (without real IDs / pass) could be useful yes !
Here it is
{'endpoints':
    {'id_device': xxxxxxxxxx, 'first_usage': '', 'id_endpoint': xxxxxxxxxx, 'picto': '', 'name': 'équipement non géré', 'last_usage': ''}
    , {'name': 'équipement non géré', 'id_endpoint': xxxxxxxxxx, 'id_device': xxxxxxxxxx, 'picto': '', 'first_usage': '', 'last_usage': ''}
    , {'id_endpoint': xxxxxxxxxx, 'last_usage': '', 'first_usage': '', 'id_device': xxxxxxxxxx, 'picto': '', 'name': 'équipement non géré'}
    , {'picto': '', 'last_usage': '', 'name': 'équipement non géré', 'first_usage': '', 'id_endpoint': xxxxxxxxxx, 'id_device': xxxxxxxxxx}
    , {'name': 'Alarme', 'id_device': xxxxxxxxxx, 'picto': 'picto_alarm', 'first_usage': 'alarm', 'id_endpoint': xxxxxxxxxx, 'last_usage': 'alarm'}
    , {'id_device': xxxxxxxxxx, 'picto': '', 'name': 'équipement non géré', 'id_endpoint': xxxxxxxxxx, 'last_usage': '', 'first_usage': ''}
, 'os': 'ios'
, 'moments': []
, 'version_application': '3.8.1 (277)'
, 'id_catalog': 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
, 'groups': [
  {'group_all': True, 'name': 'TOTAL', 'usage': 'light', 'id': xxxxxxxxxx, 'picto': 'picto_lamp'}
  , {'picto': 'picto_shutter', 'group_all': True, 'name': 'TOTAL', 'id': xxxxxxxxxx, 'usage': 'shutter'}
  , {'group_all': True, 'id': xxxxxxxxxx, 'picto': 'picto_awning_awning', 'usage': 'awning', 'name': 'TOTAL'}
, 'date': 1593174091
, 'scenarios': []
, 'old_tycam': True
, 'version': '1.0.1'}
The issue comes from the empty last_usage string. I think the last PR by Baptiste try to address the issue, did you try last update ?
Sorry @WiwiWillou, I didn’t saw your last message in time !
Just done the uodate and tried again, but it seems I have the same error :cry:
Here is what I get after the JSON
1590338188 not in dic device_name
1590338188 not in dic device_type
1590338188
1590338189 not in dic device_name
1590338189 not in dic device_type
1590338189
Hi, everybody,
Very good job. Thanks.
Im a newbie with HA, could you help me please ?
I use HAssio on a nuc.
How should i install this ? HACS ?
i have ever mosquitto.
Thanks a lot
SORRY I find :wink: with hassio, add the repository and goooo :slight_smile:
Hello @WiwiWillou,
I got some news for you because I succeed to get it work!
I didn’t understand why I got this issue :
Because by searching on the config file, i well found the device id and it is my alarm.
I saw that device_name.keys() and device_type.keys() was always empty and mainly, I noticed that the config json was considered as msg_type = ‘msg_data’ and not msg_type = ‘msg_config’
The JSON received start for me by id_catalog.
I changed your script like that
          if (("id_catalog" in first) or ("date" in first) or ("ios" in first)): #ios for tonioa case (maybe for all iOs users)
                print(">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>")
                print('Incoming message type : config detected')
                msg_type = 'msg_config'
          elif ("id" in first):
                print('Incoming message type : data detected')
                msg_type = 'msg_data'
Start with msg_config and add id_catalog.
Finally it detected config json and fill the array device regarding last_usage value !!!
I noticed also that if I add a scenario through my tydom app, the config json start with the scenario. So maybe, it will not enter in the right msg_type again…
Don’t know if I posted on the right place this post but can you update your script to have HA addon updated ?
Hi! Moved in to a new house, starting to get my HA up and running. Checked behind the light switches in the kitchen and found a Delta Dore Tyxia 2600 wired up. What kind of hardware do I need to get this talking to my MQTT broker? I have no other Delta dore stuff (that I know of) :slight_smile:
Probably a tydom box, or just change to something zigbee powered+a conbee, you won’t regret it !
