I have the following code to show an action button:
type: custom:state-switch
entity: user
default: default
states:
Ich:
type: button
icon: mdi:weather-night
entities:
- input_button.gute_nacht
tap_action:
action: call-service
service: automation.trigger
service_data:
entity_id: automation.gute_nacht
My question is, can I show this button only in a certain period of time for example between 22:00 - 24:00 o clock?
Dujith
(Charles Evers)
June 5, 2022, 7:04pm
2
There is the conditional card:
But that will only look at 1 condition and not a range so you will have to work around that.
Simplest way i think would be a template binary sensor that uses time for the value template.
template:
- binary_sensor:
- name: "button_name_visible"
state:'{{ '22:00' <= states.sensor.time.state <= '23:59' }}'
Then you can use this entity as the condition for the conditional card.
You do need to use the time_date
integration:
There is another way to use time but i found using this sensor so much easier to use in these kind of situations.
Thank you, but now I have a problem with this.
I put the following in the sensor.yaml:
- platform: time_date
display_options:
- 'time'
Restart my HA
Then I would like to put the following code in the cutomation.yaml:
template:
- binary_sensor:
I got this error:
can not read an implicit mapping pair; a colon is missing at line 176, column 67
… sensor.time.state <= ‘23:59’ }}’
The line 176 is:
state:’{{ ‘22:00’ <= states.sensor.time.state <= ‘23:59’ }}’
What I make wrong?
Dujith
(Charles Evers)
June 5, 2022, 7:49pm
5
You did nothing wrong. The code i gave you was wrong. The times should be in " instead of ’
Something i have to wrap my head around, it resolves correctly in the dev tools but fails here.
So it should be:
template:
- binary_sensor:
- name: 'button_name_visible'
state: '{{ "22:00" <= states.sensor.time.state <= "23:59" }}'
Edit: I now see why its wrong. The code i gave single quoted the brackets.
So jinja saw:
Dujith
(Charles Evers)
June 6, 2022, 8:39pm
7
No problem, but you marked yourself as the solution. And that post still has the error in it
Sorry I have lost my ready code and now I can’t get the code anymore.
I have this code again:
entity: user
default: default
states:
Ich:
type: button
entities:
tap_action:
service_data:
I have create this button:
button_anzeigen
And I don´t know to add this part into my code:
type: conditional
conditions:
- entity: button_anzeigen
state: "on"
Dujith
(Charles Evers)
June 22, 2022, 4:52pm
10
You make the conditional card and in it you put the custom:state-switch
card.
( rtfm )
type: conditional
conditions:
state: "on"
card:
entity: user
default: default
states:
Ich:
type: button
entities:
tap_action:
service_data:
I have try many thinks, maybe I have put one space to mutch.
Thank you
But now I have one more question.
How can I add to this code that it is only displayed on Wednesday and Friday?
Dujith
(Charles Evers)
June 22, 2022, 6:29pm
12
If your timeslot is still the same then its just a question of adding another condition to the template. In this case an AND / OR
with now().weekday()
that will give you the week of the day. With 0 being Monday and 6 being Sunday. So 2 and 4 for Wednesday and Friday
'{{ ("20:00" <= states.sensor.time.state <= "23:59") and (now().weekday() == 2 or now().weekday() == 4)}}'
Without the timeslot:
'{{ now().weekday() == 2 or now().weekday() == 4}}'
Ok, I have try something.
With the following code:
configuration.yaml:
template:
binary_sensor:
state: ‘{{ (“15:30” <= states.sensor.time.state <= “19:30”) and (now().weekday() == 2 or now().weekday() == 4)}}’
Button:
type: conditional
conditions:
- entity: button_anzeigen_fertig_schiessen
state: 'on'
card:
entity: user
default: default
states:
Manuel:
type: custom:mushroom-template-card
primary: Bin fertig mit Schiessen
icon: mdi:bow-arrow
layout: vertical
icon_color: green
tap_action:
confirmation:
text: Nachricht wirklkich schicken?
service_data:
entity_id: automation.sprachansage_bogenschiessen_bin_fertig
I saw the button in the edit mode. If I close the editmode the button is no longer displayed.
The state of “button_anzeigen_fertig_schiessen” is at the moment on.
What make I wrong?
Dujith
(Charles Evers)
June 24, 2022, 8:43pm
14
Shouldnt that be something like:
- entity: binary_sensor.button_anzeigen_fertig_schiessen
I’m really embarrassed now I’ll try that
