I am not sure if the Razberry works with HassOS. Anyone correct me if I am wrong, as I had no success with it.
Though, it works if you install Rasöbian, where you can disable bluetooth, and then install Home Assistant with docker or in virtual environment. But you will not get the same plug-and-play feeling, and there is more fiddling customizing the system.
If we know how to disable bluetooth with HassOS, it would be great though!
Yep, really nice to fit on the Raspberry, and it works well for the small network I have.
But it works if you install Homeassistant on Raspbian.
The negative here is it requires you to be familiar with Linux and system-maintenance.
