Bought this item (https://it.aliexpress.com/item/1005003741939416.html?gatewayAdapt=glo2ita&spm=a2g0o.9042311.0.0.10124c4dhYaVI8) a 20Amp smart plug tuya Zigbee.
Model TZ3000_bfn1w0mm as shown on HA. No metering present.
Other similar products (i.e. TZ3000_bfn1w0mm same TS011F family but 16amp smart plug) have working metering!
Describe the solution you’d like
It would be appreciated if metering could be added to this new variant of the smart plug.
code
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x010a",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0702",
"0x0b04",
"0xe000",
"0xe001"
"out_clusters": [
"0x000a",
"0x0019"
"manufacturer": "_TZ3000_gjnozsaz",
"model": "TS011F",
"class": "zhaquirks.tuya.ts011f_plug.Plug"
Anybody has a solution?
