_TZ3000_qaaysllp TS0201 not work Neo Tuya Temperature, Humidity and Illumination
I have a TS0201 _TZ3000_qaaysllp Neo Tuya Temperature, Humidity and Illumination sensor integrated into Home Assistat via a Sonoff Zigbee 3.0 hub.
However, it does not recognize the temperature and humidity values.
I have found a possible solution in the following link, but I do not know how to implement it:
I am quite new to this. How and where do I make the changes you propose?
sorry for my bad english
Thank you very much
From the blakadder page:
Issue (as of 29 Nov 21)
The device doesn’t display the temperature or humidity until it is pre-paired with an existing Tuya Gateway
I know what you’re saying. In the link contained in my previous message there is a procedure that achieves it without resorting to pairing it with a Tuya hub. My question was about how to implement what was explained in the link.
Did you ever get a resolution on this? I am now faced with the same issue.
I have a TS0201 running with this solution:
My TS0201 has no illumination sensor, just temp. and humid.
But I needed a newer version than ‘stable’ to get it running.
