_TZ3210_dwytrmda TS130F curtain driver not working
I bought two OXT curtain drivers but cannot make one of them working. Visually they look exactly the same but identify them self with different values. The “broken” one identify itself as
The issue is that “Quirk” is not loaded. When I press a physical button, the curtain is mowing but only when the button is pressed, not till is fully open or closed. The opening percentage inside HA seems reversed, so when the curtain is physically closed I no longer can open it because the up button is deactivated. Similar, when it’s physically open, the down button get deactivated. And cannot find a way to calibrate it.
When I open “Manage Zigbee Device” I cannot see TuyaCoveringCluster, but instead I see WindowCovering Cluster, but all attributes there have value ‘None’ when try to read them.
Device signature
  "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
  "endpoints": {
    "1": {
      "profile_id": 260,
      "device_type": "0x0202",
      "in_clusters": [
        "0x0000",
        "0x0004",
        "0x0005",
        "0x0102"
      "out_clusters": [
        "0x000a",
        "0x0019"
    "242": {
      "profile_id": 41440,
      "device_type": "0x0061",
      "in_clusters": [],
      "out_clusters": [
        "0x0021"
  "manufacturer": "_TZ3210_dwytrmda",
  "model": "TS130F",
  "class": "zigpy.device.Device"
Is any way to make that driver working?
Writing the own variant of quark solved an issue:
After all, it’s not fully working. Device don’t update attribute value for “current_position_lift_percentage” so HA don’t know if curtain is open or closed. Don’t have idea why. I even bought different device but has exactly same issue.
Does this device require some special initialization to start work?
Im having the same issue with the value current_position_lift_percentage not changing to the new number. so when the value is set to 100 and i close the roller shades all the way it says closed but after a couple of minutes it changes back to open.
Have you already found a solution to this problem?
I did want to let you know that the problem is not solved but i created a couple of automations(Set zigbee cluster attribute), for some percentages and for the opening and closing positions and it changes the attribute to the good value. For now this is ok with me
