TZE200_9yapgbuv temperature and humidity sensor
reference
This device has already been requested. The issue is closed with a reference to Z2M. But the device is still not in
So I think this issue should still be open. Or do I see this wrong?
Thanks in advance.
I have the same sensor. This type dont have a display.
_TZE200_9yapgbuv
A sensor with 3 entities. Temperature, Humidty and Battery.
The pairing wasnt a problem. The problem is that I do not get any data. I have 3 entities.
I am using Home Assistant with a Sky Connect Stick.
IEEE: a4:c1:38:1a:2f:92:3c:fb
Nwk: 0xad81
Device Type: EndDevice
LQI: 40
RSSI: -90
Zuletzt gesehen: 2023-03-01T10:18:28
Energiequelle: Battery or Unknown
Eigenart: zhaquirks.tuya.ts0601_sensor.TuyaTempHumiditySensorVar03
Same issue, any solution?
