I am using ZHA with the ts0601_trv_beca.py
quirk.
Everything is working fine except for one thing.
When I change the temperature calibration of the device, the local temperature is not updated accordingly.
it takes a realy long time for the change to appear in HA.
Here are a few things I noted:
- The problem is not present on a Avatto ME167 TRV using the
ts0601_trv_me167.py
. - Before switching to ZHA, I was using zigbee2mqtt and the issue was not present. For this reason, I do not think this is a device limitation.
- I tried modifying the reporting frequency using zha_toolkit command but that did not change anything.
- After the calibration change, I see that the local temperature is correctly updated on the device itself.
Any idea on how to fix this?
Setup:
- HA image with
- Core 2023.11.2
- Supervisor 2023.11.3
- Operating System 11.1
- UX 20231030.2
- Zigbee coordinator based on efr32mg21
- hardware : Raspberry Pi 3
