_TZE204_ztc6ggyl microwave sensor - cannot change any settings
Hello All,
I have 3 microwave presence sensors _TZE204_ztc6ggyl. I’m using Quirk: presence_sensor.TuyaMmwRadarOccupancy. It worked fine for years for all 3 devices. Now out of sudden when I try change any of those options:
I got error like this:
Failed to perform the action number/set_value. Failed to convert attr_value=7.0 from type <class 'zigpy.types.basic.Single'> to int | str
In GUI itself value changes but is not send to device. Presence detection and LUX measuring works however. Any ideas?
I cannot find from where did I downloaded this quirk exactly but here’s the code:
import math
from typing import Dict, Optional, Tuple, Union
from zigpy.profiles import zha
from zigpy.quirks import CustomDevice
import zigpy.types as t
from zigpy.zcl import foundation
from zigpy.zcl.clusters.general import (
    AnalogInput,
    AnalogOutput,
    Basic,
    GreenPowerProxy,
    Groups,
    Identify,
    Ota,
    Scenes,
    Time,
from zigpy.zcl.clusters.measurement import (
    IlluminanceMeasurement,
    OccupancySensing
from zigpy.zcl.clusters.security import IasZone
from zhaquirks import Bus, LocalDataCluster, MotionOnEvent
from zhaquirks.const import (
    DEVICE_TYPE,
    ENDPOINTS,
    INPUT_CLUSTERS,
    MODEL,
    MOTION_EVENT,
    OUTPUT_CLUSTERS,
    PROFILE_ID,
from zhaquirks.tuya import (
    NoManufacturerCluster,
    TuyaLocalCluster,
    TuyaNewManufCluster,
from zhaquirks.tuya.mcu import (
    # TuyaDPType,
    DPToAttributeMapping,
    TuyaAttributesCluster,
    TuyaMCUCluster,
class TuyaMmwRadarSelfTest(t.enum8):
    """Mmw radar self test values."""
    TESTING = 0
    TEST_SUCCESS = 1
    TEST_FAILURE = 2
    OTHER = 3
    COMM_FAULT = 4
    RADAR_FAULT = 5
class TuyaOccupancySensing(OccupancySensing, TuyaLocalCluster):
    """Tuya local OccupancySensing cluster."""
class TuyaIlluminanceMeasurement(IlluminanceMeasurement, TuyaLocalCluster):
    """Tuya local IlluminanceMeasurement cluster."""
class TuyaMmwRadarSensitivity(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for sensitivity."""
    def __init__(self, *args, **kwargs):
        """Init."""
        super().__init__(*args, **kwargs)
        self._update_attribute(
            self.attributes_by_name["description"].id, "Sensitivity"
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 1)
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 9)
        self._update_attribute(self.attributes_by_name["resolution"].id, 1)
class TuyaMmwRadarMinRange(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for min range."""
        """Init."""
            self.attributes_by_name["description"].id, "Min range"
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 0)
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 950)
        self._update_attribute(self.attributes_by_name["resolution"].id, 10)
            self.attributes_by_name["engineering_units"].id, 118
        )  # 31: meters
class TuyaMmwRadarMaxRange(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for max range."""
        """Init."""
            self.attributes_by_name["description"].id, "Max range"
        )  # 31: meters
class TuyaMmwRadarDetectionDelay(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for detection delay."""
        """Init."""
            self.attributes_by_name["description"].id, "Detection delay"
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 000)
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 20000)
        self._update_attribute(self.attributes_by_name["resolution"].id, 100)
            self.attributes_by_name["engineering_units"].id, 159
        )  # 73: seconds
class TuyaMmwRadarFadingTime(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for fading time."""
        """Init."""
            self.attributes_by_name["description"].id, "Fading time"
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 0000)
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 200000)
        self._update_attribute(self.attributes_by_name["resolution"].id, 1000)
        )  # 73: seconds
class TuyaMmwRadarTargetDistance(TuyaAttributesCluster, AnalogInput):
    """AnalogInput cluster for target distance."""
        """Init."""
            self.attributes_by_name["description"].id, "Target distance"
            self.attributes_by_name["engineering_units"].id, 31
        )  # 31: meters
class TuyaMmwRadarCluster(NoManufacturerCluster, TuyaMCUCluster):
    """Mmw radar cluster."""
    attributes = TuyaMCUCluster.attributes.copy()
    attributes.update(
            # ramdom attribute IDs
            0xEF01: ("occupancy", t.uint32_t, True),
            0xEF02: ("sensitivity", t.uint32_t, True),
            0xEF03: ("min_range", t.uint32_t, True),
            0xEF04: ("max_range", t.uint32_t, True),
            0xEF06: ("self_test", TuyaMmwRadarSelfTest, True),
            0xEF09: ("target_distance", t.uint32_t, True),
            0xEF65: ("detection_delay", t.uint32_t, True),
            0xEF66: ("fading_time", t.uint32_t, True),
            0xEF67: ("cli", t.CharacterString, True),
            0xEF68: ("illuminance", t.uint32_t, True),
    dp_to_attribute: Dict[int, DPToAttributeMapping] = {
        1: DPToAttributeMapping(
            TuyaOccupancySensing.ep_attribute,
            "occupancy",
            # dp_type=TuyaDPType.BOOL,
        2: DPToAttributeMapping(
            TuyaMmwRadarSensitivity.ep_attribute,
            "present_value",
            # dp_type=TuyaDPType.VALUE,
        3: DPToAttributeMapping(
            TuyaMmwRadarMinRange.ep_attribute,
            "present_value",
            endpoint_id=2,
            #converter=lambda x: x / 100,
            #dp_converter=lambda x: x * 100,
        4: DPToAttributeMapping(
            TuyaMmwRadarMaxRange.ep_attribute,
            "present_value",
            endpoint_id=3,
        6: DPToAttributeMapping(
            TuyaMCUCluster.ep_attribute,
            "self_test",
            # dp_type=TuyaDPType.ENUM,
        9: DPToAttributeMapping(
            TuyaMmwRadarTargetDistance.ep_attribute,
            "present_value",
        101: DPToAttributeMapping(
            TuyaMmwRadarDetectionDelay.ep_attribute,
            "present_value",
            dp_converter=lambda x: x // 100,
            endpoint_id=4,
        102: DPToAttributeMapping(
            TuyaMmwRadarFadingTime.ep_attribute,
            "present_value",
            endpoint_id=5,
        103: DPToAttributeMapping(
            "cli",
            # dp_type=TuyaDPType.STRING,
        104: DPToAttributeMapping(
            TuyaIlluminanceMeasurement.ep_attribute,
            "measured_value",
            converter=lambda x: int(math.log10(x) * 10000 + 1) if x > 0 else int(0),
    data_point_handlers = {
        1: "_dp_2_attr_update",
        2: "_dp_2_attr_update",
        3: "_dp_2_attr_update",
        4: "_dp_2_attr_update",
        6: "_dp_2_attr_update",
        9: "_dp_2_attr_update",
        101: "_dp_2_attr_update",
        102: "_dp_2_attr_update",
        103: "_dp_2_attr_update",
        104: "_dp_2_attr_update",
class TuyaMmwRadarOccupancy(CustomDevice):
    """Millimeter wave occupancy sensor."""
    signature = {
        #  endpoint=1, profile=260, device_type=81, device_version=1,
        #  input_clusters=[0, 4, 5, 61184], output_clusters=[25, 10]
        "models_info": [
            ("_TZE200_ar0slwnd", "TS0601"),
            ("_TZE200_sfiy5tfs", "TS0601"),
            ("_TZE200_mrf6vtua", "TS0601"),
            ("_TZE200_ztc6ggyl", "TS0601"),
            ("_TZE204_ztc6ggyl", "TS0601"),
        ENDPOINTS: {
            1: {
                PROFILE_ID: zha.PROFILE_ID,
                DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    TuyaNewManufCluster.cluster_id,
                OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
    replacement = {
        ENDPOINTS: {
            1: {
                DEVICE_TYPE: zha.DeviceType.OCCUPANCY_SENSOR,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    TuyaMmwRadarCluster,
                    TuyaIlluminanceMeasurement,
                    TuyaOccupancySensing,
                    TuyaMmwRadarTargetDistance,
                    TuyaMmwRadarSensitivity,
            2: {
                DEVICE_TYPE: zha.DeviceType.COMBINED_INTERFACE,
                INPUT_CLUSTERS: [
                    TuyaMmwRadarMinRange,
                OUTPUT_CLUSTERS: [],
            3: {
                INPUT_CLUSTERS: [
                    TuyaMmwRadarMaxRange,
            4: {
                INPUT_CLUSTERS: [
                    TuyaMmwRadarDetectionDelay,
            5: {
                INPUT_CLUSTERS: [
                    TuyaMmwRadarFadingTime,
Same issue here…
Failed to convert attr_value=3.0 from type <class ‘zigpy.types.basic.Single’> to int | str
This happened after October/24 update
Even if I try to change the attibute directly to on the device, it does not work
Anyone found a fix for this?
Yeah same thing here, man this is all janky, what a bummer…I’m trying to figure out the error, but no luck yet…
Definatelly HA issue. My quirk worked for years and suddenly stopped. I also tried few other quirks and no luck. Also I made an error in my initial post. I have 1x _TZE204_ztc6ggyl and 2x TZE204_qasjif9e same as you do. They both worked fine on the same quirk till now.
Exactly the same problem with my recently acquired _TZE204_ya4ft0w4 version of the sensor.
It seems to be working OK with the defaults for this particular use case, but I’d need to change at least two parameters for two other installs I have in mind, so a solution would be extremely welcome.
To be honest I don’t want to do this if I really don’t have to but did anyone tried to re-pair any of those devices? Did it fixed anything?
2024.12 update fixed it!
Now, something else came up. When I change any of the sensor settings, it reverts immediately (or after a while) to the default (I guess) settings.
Does anyone have a clue on how to fix this?
