Joe3
February 26, 2022, 4:32am
1
This sends “input_text.test” instead of “Hello,world” ?
text_sensor:
- platform: homeassistant
entity_id: input_text.text_tx # ha helper
on_value: # On Change
then:
- uart.write: input_text.text_tx
and this errors out
text_sensor:
then:
- uart.write: !lambda
return id(text_tx).state;
Joe3
February 26, 2022, 5:37am
3
Compiling /data/office-8x8/.pioenvs/office-8x8/src/main.cpp.o
/config/esphome/office-8x8.yaml: In lambda function:
/config/esphome/office-8x8.yaml:82:23: error: could not convert ‘text_tx->esphome::homeassistant::HomeassistantTextSensor::.esphome::text_sensor::TextSensor::state’ from ‘std::string {aka std::basic_string}’ to ‘std::vector’
/config/esphome/office-8x8.yaml:83:3: warning: control reaches end of non-void function [-Wreturn-type]
*** [/data/office-8x8/.pioenvs/office-8x8/src/main.cpp.o] Error 1
========================== [FAILED] Took 3.81 seconds ==========================
tom_l
February 26, 2022, 6:37am
4
See if this helps:
I found a solution myself
on_value:
char buf[128];
sprintf(buf, "Temperature: %.1f degrees \n", id(temperature).state);
std::string s = buf;
return std::vector<unsigned char>( s.begin(), s.end() );
So in your case think it goes like this:
on_value:
char buf[128];
sprintf(buf, id(text_tx).state);
Joe3
February 26, 2022, 6:29pm
5
I bet that would work if I didn’t get this error.
/config/esphome/office-8x8.yaml:82:49: error: cannot convert ‘std::string {aka std::basic_string}’ to ‘const char*’ for argument ‘2’ to ‘int sprintf(char*, const char*, …)’
========================== [FAILED] Took 3.59 seconds ==========================
Did I space something wrong?
text_sensor:
then:
char buf[128];
Joe3
February 27, 2022, 7:36am
6
tom_l did this not give you the same error?
tom_l
February 27, 2022, 8:06am
7
No, because I’m not using it.
I use a custom Home Assistant Service in ESPHome rather than a text sensor:
api:
services:
- service: write
variables:
command: string
then:
- uart.write:
data: !lambda |-
std::string str = command;
std::vector<uint8_t> vec(str.begin(), str.end());
return vec;
uart:
tx_pin: GPIO12
rx_pin: GPIO32
baud_rate: 9600
To use it in Home Assistant:
- service: esphome.projector_uart_write
command: "KEY 20\r\n"
'projector_uart` is the ESP device name.
Joe3
February 27, 2022, 8:19am
8
I’m giving what you got a try. Question? what is - service: under or what yaml file? in homeassistant: ?
tom_l
February 27, 2022, 9:33am
9
You call services using automation actions or script sequences. Or for testing you can use Developer Tools / Services.
Here’s one of my scripts:
script:
projector_menu:
sequence:
command: "KEY 03\r\n"
Joe3
February 27, 2022, 9:36am
10
Was just going to reply that it worked and thank you !!!
In an Automation
- id: '1645952179094'
alias: Test uart service call
description: ''
- platform: state
entity_id: input_boolean.test_toggle
to: 'on'
condition: []
- service: esphome.office_8x8_write
command: S000,O,red,off,020
In the ESPHome
# Enable Home Assistant API
api:
services:
- service: write
variables:
command: string
then:
- uart.write:
data: !lambda |-
return vec;
uart:
tx_pin:
number: D0
#inverted: true
rx_pin:
number: D1
#inverted: true
baud_rate: 19200 #9600
Thank you again
@Joe3 and/or @tom_l , are you able to confirm if you’ve gotten this working via an input_text (or other method for setting via the front end)?
eg like this:
service: esphome.scorbot_quinled_write
command: "{{states.input_text.scorbot_command.state}}"
I’m trying to get some help over on Discord with issues with escape sequences. Cheers.
Discord is the easiest way to communicate over voice, video, and text. Chat, hang out, and stay close with your friends and communities.
Edit: Solved by @ssieb on Discord. Thanks!
\r was being stuborn…
api:
services:
- service: write
variables:
command: string
then:
- uart.write:
data: !lambda |-
std::size_t pos;
while ((pos = str.find("\\r")) != std::string::npos)
str.replace(pos, 2, "\r");
return vec;
Or another way I prefer:
In HA:
input_text:
scorbot_command:
initial: "1M+100\r2M+100\r3M+100\r"
In Esphome:
text_sensor:
name: "HA Scorbot Command"
entity_id: input_text.scorbot_command
internal: false
button:
name: "Execute HA Command"
on_press:
- logger.log: Execute HA Command 1
- uart.write:
data: !lambda |-
std::size_t pos;
std::string str = id(ha_scobot_text_command).state;
return vec;
ElVit
July 27, 2024, 1:50pm
12
I found a way to write a hex string from a template text component to uart. I use the function parse_hex
from the ESPHome helpers class.
text:
optimistic: true
min_length: 0
max_length: 100
mode: text
initial_value: "f1f10100017e"
button:
on_press:
- uart.write: !lambda |-
auto str = id(templ_text).state;
std::vector<uint8_t> out;
auto ret = parse_hex(str, out, str.length() / 2);
return out;
tom_l
July 27, 2024, 11:47pm
13
I could create a button in esphome for each command I have for my projector rather than creating a script in home assistant to send the data for each command. Then I would just use the button press service for each command. Same amount of entities, (buttons instead of scripts) but a little less complicated.
However there is other logic that needs too be incorporated to prevent button collisions while waiting for the projector to process the command so I doubt I’ll bother.
projector_menu:
sequence:
- condition: state
entity_id: input_boolean.uart_busy # collision prevention
state: 'off'
- delay: 1
- service: input_boolean.turn_off
The delay can be different for each command (40 sec for power_on!).
