Hi, i use Hassio 0.108.9, i try to ad device_tracker:- platform: unifi_direct but no device tracker found.
Why?
Thnaks
Share the config you used.
Are there any errors in the log?
device_tracker:
host: 192.168.xxxx
username: xxxxxx
password: xxxxx
interval_seconds: 10
consider_home: 120
No error log
And no know_devece.yaml create…
I don’t believe that the device_tracker.yaml file is used anymore.
Take a look at your state page in the developer tools for device_tracker entities.
In developer tools, no device_tracker entities found…
And nothing in home-assistant.log
No error in log file.
I found braking change in 0.108.x: UniFi - Manual configuration has been deprecated as the UI integration now supports all of the previous available options and more. Your existing YAML configuration has previously been imported so just remove it. But i use unifi_direct presence detection… they are different things, or this is the problem?
That is a separate integration. That one utilizes the controller for information.
Without anything in the logs its hard to troubleshoot. Double check all your settings.
