-When contact http://192.168.0.1:7080/api/2.0/camera it seems Unifi NVR is expecting login. This seems to cause “NVR refuses to talk to me” in HA
SOLUTION: not sure. maybe need to send login, then attempt connection (if fail, try login,)
I’m getting the following error and not using an aircam, it is a UVC Micro:
ERROR:homeassistant.components.camera:Error while setting up platform uvc
File “/home/base/home-assistant/homeassistant/helpers/entity_component.py”, line 98, in _setup_platform
discovery_info)
File “/home/base/home-assistant/homeassistant/components/camera/uvc.py”, line 50, in setup_platform
cameras = [camera for camera in cameras
File “/home/base/home-assistant/homeassistant/components/camera/uvc.py”, line 51, in
if ‘airCam’ not in nvrconn.get_camera(camera[‘uuid’])[‘model’]]
File “/home/base/.local/lib/python3.5/site-packages/uvcclient/nvr.py”, line 204, in get_camera
return self._uvc_request(’/api/2.0/camera/%s’ % uuid)[‘data’][0]
File “/home/base/.local/lib/python3.5/site-packages/uvcclient/nvr.py”, line 76, in _uvc_request
return self._uvc_request_safe(*args, **kwargs)
File “/home/base/.local/lib/python3.5/site-packages/uvcclient/nvr.py”, line 105, in _uvc_request_safe
raise NvrError(‘Request failed: %s’ % resp.status)
uvcclient.nvr.NvrError: Request failed: 404
