This component seems to work sporadically. I have devices which have been disconnected for more than 4 hrs is still showing “Home”. I checked my Unifi controller and the devices are not showing connected. Restarted HA a few times, still not updating the status. Anyone having same problem or how to solve this? My config:
Thanks. That was my next option but wanted to first check with the community if this is a bug with this component or has anyone else experienced same issue/has been successful using this with some tweaks. Is the other Unifi component any more reliable? Any experience with using it?
no errors except for the occasional “(MainThread) [homeassistant.core] Timer got out of sync. Resetting”. I added a new device for tracking this morning and that one updated, so something is working
logger:
default: warn
logs:
homeassistant.components.device_tracker: info
homeassistant.components.automation: debug
homeassistant.components.light: info
homeassistant.components.sensor: info
homeassistant.components.switch: info
Its now updating… What I did was connected the troubled device to another AP, waited a few mins, reconnected to this tracked AP and then disconnected. Now it seems to be working. Strange!
With device connected to Unifi and showing as Home in HASS, shutdown HASS server
Disconnect device from Unifi, wait till device disappears from Client list in the Unifi controller
Start up HASS server
Waited 15 mins and device still continues to show as “Home” eventhough the device does not exist when I dump using mca-dump | tr -d “\n”. Restarting HASS does not update status either. But reconnecting device to Unifi and disconnecting will trigger the update
Are there any updates on this issue? I just picked up a bunch of Ubiquiti gear and am having this same issue. Unifi direct AP shows me as home all the time even after several hours of being away. At the moment I’m not running the controller all the time so that’s not an option for me at this time.
Are you having this issue without shutting down Hass? I haven’t seen this problem my self, and I haven’t looked in to it I have been really busy lately.
Really the only troubleshooting that I’ve done is I had initially manually added my phone into known_devices.yaml, so I removed it and then had the unifi_direct component add it automatically after disconnecting and reconnecting my phone to the AP.
I have since put my phone on an old Netgear AP that I haven’t decommissioned yet, and it’s been on that for almost an hour. HA still shows my status as home.
I also JUST did the update to 0.69 and rebooted the whole system afterwards. HA still shows me as home even with my phone not connected to the AP at all. Controller shows no devices connected to AP.
Let me know if there is some way I can help troubleshoot anything. I’ve never gotten any kind of device tracker to work reliably and I was hoping to finally get it with Unifi.
So this appears to be a bug with Home Assistant not the unifi component. You will see this same issue on all router based trackers. I am looking in to it but it gets in to the core HA stuff and I am not too familiar with it.
