I’m configuring Ubiquiti Unifi WLAN AP to work as a device tracker. But my problem is that I’m not able to get home assistant to login to the AP when setting up the component. In HA logs it says “Password refused” and when I checked the logs from the AP it says that there are three attempts to login for “non-existent user”.
I have created a new user for home assistant and that works when trying to login from computer. I have also tried admin user but that also fails to login. Is there some trick that I do not know? The password does not contain any special chars and I have tried with ’ ’ and without.
Here is my config:
device_tracker:
- platform: unifi_direct
host: IP
username: 'username'
password: 'password'
Edit:
Of course now I was able to get it to login but only as the admin and I do not want that. Has anyone any tips on why it might be that the home assistant user is failing? The password is 27 chars long.
