Ubiquiti UniFi G3 as motion detector
Does anybody know if the Ubiquiti UniFi G3 can be used as a motion detector? This would be very convenient as I don’t have to put up cables for additional motion detectors.
If not, my plan is to use the Aeotec multi sensor 6. How would you wire this one as it uses usb?
i fount solution in google (dont remember site)
i ran script.sh on unifi server:
#!/bin/bash
Unifi Video Vars
UNIFI_MOTION_LOG=/var/log/unifi-video/motion.log
MQTT Vars
MQTT_SERVER=“IP##########”
MQTT_TOPIC_BASE=“camera/motion”
MQTT User/Pass Vars, only use if needed
MQTT_USER="#############"
MQTT_PASS="##############"
Camera Defs
CAM1_NAME="##############"
CAM1_ID="################3"
Script starts here
if [[ -n “$MQTT_USER” && -n “$MQTT_PASS” ]]; then
$MQTT_USER_PASS="-u $MQTT_USER -P $MQTT_PASS"
else
$MQTT_USER_PASS=""
fi
while inotifywait -e modify $UNIFI_MOTION_LOG; do
LAST_MESSAGE=tail -n1 $UNIFI_MOTION_LOG
LAST_CAM=echo $LAST_MESSAGE | awk -F '[][]' '{print $2}'
LAST_EVENT=echo $LAST_MESSAGE | cut -d ':' -f 5 | cut -d ' ' -f 1
if echo $LAST_CAM | grep -n1 $CAM1_ID; then
# Camera 1 triggered
if [[ $LAST_EVENT == “start” ]]; then
echo “Motion started on $CAM1_NAME”
mosquitto_pub -h $MQTT_SERVER $MQTT_USER_PASS -r -t $MQTT_TOPIC_BASE /$CAM1_NAME -m “ON” &
else
echo “Motion stopped on $CAM1_NAME”
mosquitto_pub -h $MQTT_SERVER $MQTT_USER_PASS -r -t $MQTT_TOPIC_BASE /$CAM1_NAME -m “OFF” &
fi
fi
done
i see sensor:
[sensor.template_pir_motion_camera1]
sensors.yaml
  • platform: template
    sensors:
    template_pir_motion_camera1:
    friendly_name: ‘Camera motion’
    value_template: >
    {%- set pirs = [states.sensor.camera1_ruch] %}
    {% for pir in pirs %}
    {% if as_timestamp(pir.last_changed) == as_timestamp(pirs | map(attribute=‘last_changed’) | max) %}
    {{pir.last_changed.astimezone(now().tzinfo).strftime(’%-H:%M’)}}
    {% endif %}
    {% endfor %}
then i can see motion in HA:
obraz
i found:
Thanks!
Do you find this solution stable and fast like a pir?
for me works stable.
its is possible to have on one view name of sensor and bottom time of last move like here:
obraz
how do this, name of sensor and bottom last activity?
I am having trouble getting this working… my config is as follows
binary_sensors:
- platform: mqtt
  state_topic: "homeassistant/camera/motion/front_door"
  friendly_name: "Front Door Camera Motion"
  payload_on: 'ON'
  payload_off: 'OFF'
  value_template: >
    {%- set pirs = [states.binary_sensor.front_door_camera_motion] %}
      {% if as_timestamp(pir.last_changed) == as_timestamp(pirs | map(attribute='last_changed') | max) %}
        {{pir.last_changed.astimezone(now().tzinfo).strftime('%m/%d @ %-H:%M')}}
      {% endif %}
    {% endfor %}
  device_class: motion
  qos: 0
and its not clear to me what I would put in groups.yaml after this to get last movement…
Can someone show me the entire config to get this working ?
no supported from 87 version, any idea how to tun this?
Is parsing the log still the only way to get HASS to know there has been motion on the UniFi cameras?
When @balloob started to work for Ubiquiti I hoped for a fully integrated solution but now that cooperation is over. Anyone knows if the situation is the same with UniFi Protect and the new Cloud Gen2+ ?
