carltonb
(Carlton Brooks)
January 23, 2021, 3:18pm
1
I have been trying to setup an automation that would tell me if I have any alerts from my unifi system.
Currently I have 7 (saved to test the automation). The automation I wrote does not seem to trigger.
It displays the messages as seen below. So I believe I have all the sensors setup correctly.
Here is my code for the automation.
- id: '1662560952541'
alias: '++A-UNIFI Notify if Unifi Gateway Alert (24DEC2020)'
description: UNIFI Notify if Unifi Gateway Alert
initial_state: true
value_template: "{{ states(' sensor.unifi_gateway_alerts') > '0' }}"
condition:
- condition: template
value_template: "{{ trigger.from_state.state != 'None' }}"
value_template: "{{ trigger.from_state.state != 'unavailable' }}"
value_template: "{{ trigger.from_state.state < trigger.to_state.state }}"
- service: notify.telegram_carlton
data_template:
title: 'Unifi Gateway Alert'
message: 'There are currently {{ trigger.to_state.state }} Unifi Gateway Alerts'
- service: persistent_notification.create
data_template:
mode: single
What is wrong with the code!
Or what else should I check to see why it will not notify me.
finity
January 23, 2021, 3:56pm
2
The trigger you have set up will only trigger one time when the state changes from 0 to above 0.
since the state is already above 0 the the trigger never transitions from false to true to trigger the automation.
And second but most importantly - all states are strings but you can’t compare a string to a string the way you are trying it.
when comparing strings with > or < it looks at the string length and compares that. So in your case 7 isn’t greater than 0, it’s equal to 0.
try this:
value_template: "{{ states(' sensor.unifi_gateway_alerts') | int > 0 }}"
carltonb
(Carlton Brooks)
January 23, 2021, 7:41pm
3
Thank you for the quick reply. I understand the thought process.
I replaced my line with the one you gave me.
Reloaded and ran it. Nothing happens.
If I take your line and put it into the template editor it says false, but in should it not state true as there are alerts.
finity
January 23, 2021, 8:40pm
4
Sorry I had a typo.
I added an extra space in the state definition.
try this instead:
value_template: "{{ states('sensor.unifi_gateway_alerts') | int > 0 }}"
carltonb
(Carlton Brooks)
January 24, 2021, 6:46pm
5
Darn spacing and quotes!
Though I now get a true statement, it still will not send me a notice.
I will continue to work my way through it.
Thank you
finity
January 24, 2021, 8:34pm
6
I believe this condition suffers from the same flaw as your trigger:
the states are strings so you are comparing string lengths instead of what you think you are comparing.
try this instead:
value_template: "{{ trigger.from_state.state | int < trigger.to_state.state | int }}"
carltonb
(Carlton Brooks)
January 25, 2021, 8:14pm
7
Thank you, I will give it a try.
