ubisys joins Works with Home Assistant
We’re thrilled to welcome ubisys to Works with Home Assistant! This German company has been dedicated to smart home automation for more than 20 years, and offers a range of Zigbee devices designed to help you retrofit your home. If retrofitting is conjuring up images of avocado bathrooms 🥑 and artexed ceilings, fear not – it just means upgrading what you already have, rather than ripping it out and starting again. Better for your home, and the planet 🌍.
Here today, here tomorrow
Founded in Düsseldorf in 2005, ubisys build devices that last. They back their hardware with a five-year warranty and software updates for the long term, meaning the device you buy today won’t end up obsolete in a few years’ time – in fact, they’re still shipping feature updates for hardware designed in 2010! That kind of longevity aligns closely with the Open Home Foundation’s own sustainability principle, and is just one reason why they’re such a great (retro)fit for the program! Zigbee is another…
Zigbee to the bone
If you’re scratching your head at the mention of Zigbee, allow me to explain: it’s a wireless standard that lets smart home devices communicate with each other, regardless of who made them. Unlike WiFi, it’s a mesh network, meaning Zigbee devices “talk” to each other, as well as to a central hub (like your Home Assistant setup), strengthening the connection across your whole home. It runs entirely locally, with no cloud dependency, and is optimized for long battery life.
For retrofit devices that need to just get on with their jobs in the background, these qualities really count, and explains why ubisys refer to Zigbee as the backbone of everything they build. And they don’t just use the standard, they help shape it: ubisys are active members of the Connectivity Standards Alliance (the organization responsible for maintaining and developing Zigbee), sitting on working groups and committees at the highest level – helping improve the standard for the benefit of the whole community. This commitment to open standards runs through everything ubisys do:
"We are convinced the future of smart homes lies in openness and robust interoperability. This partnership is a testament to that shared vision, and represents a significant step in deepening our integration with Home Assistant -- helping empower the most vibrant, tight-knit community in the smart home space. This community is the true engine of innovation. By achieving this certification, we're ensuring our devices integrate more seamlessly than ever into Home Assistant's robust ecosystem, providing the reliability and performance this community expects and deserves. We look forward to supporting the brilliant, custom solutions they will build."
- Dr.-Ing Arasch Honarbacht, Founder & Engineering Lead
Devices
Every device in the Works with Home Assistant program is put through its paces by our in-house team before it earns certification, so when you see the badge, you know it works. But that’s not all: every partner must also commit to providing long-term support and firmware updates, and engaging with our community – all things we’re confident ubisys will deliver, for the reasons outlined above! 👆
These are the first Works with Home Assistant-certified Zigbee devices designed to fit behind your existing wall fixtures. Together they cover switch and scene control, energy monitoring, and heating:
It’s important to note that the actuators and control unit involve mains electricity, so must be installed by a qualified electrician: check the ubisys website for guidance. The H1 is more straightforward, since it simply clips onto your existing radiator valve and runs on AA batteries.
Ready to retrofit?
To use these devices with Home Assistant, you need a Zigbee adapter (a USB dongle that allows everything to communicate), and to enable Home Assistant’s built-in Zigbee Home Automation (ZHA) integration, which takes care of the rest. ZHA is supported by the Open Home Foundation, with full-time developers dedicated to working on it and helping certify new Works with Home Assistant Zigbee devices.
If you’d like to support this work, a Home Assistant Cloud subscription helps fund ZHA and the wider Open Home Foundation mission – all while giving you secure, remote access to your smart home.
We hope ubisys’s inclusion in the program means more Home Assistant users can upgrade their smart homes without starting from scratch – and with our certified device list growing all the time, there’s never been more ways to build the way you want. We look forward to seeing what you get up to! 👀
Frequently asked questions
If I have a device that is not listed under Works with Home Assistant, does this mean it’s not supported?
No! It just means that it hasn’t gone through a testing schedule with our team or doesn’t fit the requirements of the program. It might function perfectly well, but be added to the testing schedule later down the road, or it might work under a different connectivity type that we don’t currently test under the program.
OK, so what’s the point of the Works with program?
It highlights the devices we know work well with Home Assistant and the brands that make a long-term commitment to keeping support for these devices going. The certification agreement specifies that the devices must have the functionality you would expect within Home Assistant, operate locally without the need for cloud, and that they will continue to do so long-term.
How were these devices tested?
All devices in this list were tested using a standard Home Assistant Green as a hub with the Home Assistant Connect ZBT-2, and with ZHA, our Zigbee integration. If you have another hub/antennae set-up/integration that’s not a problem, but we test against these as they are the most effective way for our team to certify within our ecosystem.
Will you be adding more ubisys devices to the program?
Why not! We’re thrilled to foster a close relationship with the team at ubisys to work together on any upcoming releases or add in further products that are not yet listed here.
Where can I see what other devices have been certified?
You can find every Works with Home Assistant device on our certified device list. All products included have been rigorously tested by our team, and are built with privacy and local control at their core by partners committed to long-term support. We also flag which regions they are available in, and any known limitations on the list so you can make a fully informed decision before you buy.
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2026/04/23/ubisys-joins-works-with-home-assistant
Nice to see more European smart home brands joining the Works with Home Assistant program!
By the way, spotted that Ubisys has also already started pushing several Zigbee OTA (Over-The-Air) firmware updates for their devices to the new zigpy-ota repository for ZHA too → GitHub - zigpy/zigpy-ota: Zigbee OTA images for zigpy/ZHA · GitHub
Some other other companies have also pushed Zigbee OTA firmware update files there for their devices too, which could maybe be a hint of upcoming Works with Home Assistant program partners as well → Launch of the zigpy-ota repo · zigpy/zigpy-ota · Discussion #2 · GitHub
Hope that many more manufacturers that makes Zigbee devices or their Zigbee firmware developers/maintainers also finds that repo and begin to submit Zigbee OTA firmware update files to it as well, regardless if they aim to get all devices certitied for WWHA or not. :grinning:
I ordered their 4 way switch actor. Shelly doesn’t offer one of those and I was looking die something like that to control my blinds. :slightly_smiling_face:
I appreciate Ubisys, because their zigbee relays properly implement zigbee bindings and support detached relay mode. When doing my research I was really surprised that almost no brand supported binding. This allowed me to:
  1. use my fancy switch plates.
  2. Have the switches turn my smart bulbs on or off via bindings.
  3. Have the bulbs always powered.
  4. Have all of this work even if HA goes down, heck, even when the zigbee coordinator bursts into flames and dies.
The only problem is that these relays are prohibitably expensive compared to a Sonoff or Aqara or a cheap Chinese relay from Aliexpress. Fortunately, today there is a alternative - there's custom firmware for tuya zigbee devices, and it works great.
