Hey Guys,
I’ve been on Raspbian forever and i’m finally moving to a NUC server running Ubuntu 18.
My first attempt is :
Ubuntu 18, Docker, Portainer and Hass container running in Host network mode as I need that for my Xiaomi Gateway for multicast.
Everything is running fine except I need to set up Lets Encrypt, to do that I understand I need to install Traefik.
But if I install Traefik then that will break multicast as home assistance cant run in host mode (–net=host )
So should I start again without docker or maybe just install Hass.IO or is there another way I’m missing?
You could use NGINX, APACHE, HAProxy, Caddy, or Traefik
Thanks, ill research them and see if I can find something that works. I do admit i’m not fluent in all things linux so sorry if that was a dumb question
HUH? Do you have documentation on why you can’t do that?
Only from research when I’ve read of other peoples problems and that multicast traffic stops getting to Hass once the container is taken out of host mode which is needed for traefik to work.
I guess ill do some more research but i’ve been struggling to find guides that have what i’m after.
At the end of the day I just want Home assistant, Mosquitto, lets encrypt and a database for recorder on Ubuntu that will accept multicast traffic so I can work with my xiaomi hub - So if you do have any recommendations on what the right solution is, i’m open to them.
Since i’m not running anything else on the NUC maybe I should just not use docker at all.
I started using docker, and ended up concluding that the maturity of the HA project is too low too make sense of a docker install. You need to install specific versions of specific modules to make things work, and some of the modules need access to some of the hardware (bluetooth for example) which is not supported in docker.
My advice would be to to stick with a well documented setup where you register everything you do.
Security vice, this requires all the usual things…
Hmm, it sounds really awesome. Do you have the bluetooth/ble device trackers working inside docker?
Rgd the different versions, I am struggling with getting IKEA tradfri, all the device tracking and MQTT messaging to work, and only got it working by manually forcing different pip3 installs to make it work. Really cumbesome work. It could have been nice with a guide to “what parts of the project has been tested or not” kind of guide. I get many many error message in the error logs every minute for many parts of the setup. The IOS app is not working to me at all either, which could also have been nice.
Long story short: If you have bluetooth running nicely inside a docker container, with the 0.82.1 version of the project I must be a complete idiot - and that might have destroyed other parts of the setup.
Ups, and rgd where I have info about docker and bluetooth, here is a few that indicates problems related to HA - but I am not an expert, just trying to extract the conclusions. And it sure seems that you have found a way out.
Hi, I dont use bluetooth from the docker container. The only bluetooth component I use is happy-bubles, which I’ve installed directly on ubuntu and works fine.
Everything else is containerised and works without issues.
I would suggest you use docker compose and have a look at different compose yamls posted here.
I can share mine if you’d like
Thank you all for your replies. I’ve been furiously beating my head against this wall but I haven’t won yet.
I got as far as having Portainer, HomeAssistant, Mosquitto and Letsencrypt/Nginx container Installed. Lets encrypt sorted the certs once I fixed a missing DNS issue an i’ve set up the Nginx config but I can only get to home assistant on the IPAddress:8123. Portainer and MQTT was working fine and so was my Xiaomi gateway.
flamingm0e - I’ve been reading you Docker Compose file and I see you don’t have Nginx or the let encrypt container in there - Do you not use it? or install it separately? (Thanks for publishing it by the way, very helpful)
I’m going to start fresh, so bear with me i’m going to break it down simple.
Install ubuntu
Install Docker
Install Docker Compose
install Letsencrypt/Nginx container?
Setup lets encrypt and Nginx subsite configs
Setup Stack in docker Compose to get Portainer, Mosquitto, hadockermon,Home assistant and node red
I use NGINX, installed on a VPS I already have for various other things, so it is not running in my local network, but on a VPS on Digital Ocean. As for Lets Encrypt, I still deal with that manually on my VPS, as I have had my setup on there for years and hate to tear it all down to replace it (it would be a lot of work).
Basically my setup is reverse proxy running on NGINX (and handles my certs) on my VPS, and my home firewall only allows traffic to my Home Assistant install from my public IP on my VPS (it’s a static IP). One day I will get around to performing either an SSH tunnel or a VPN between the VPS and my home network.
Ah ok, thanks for that. I’ve read too many different guides - some were installing lets encrypt outside of docker and I was wondering if that was what you had done.
So no problem putting the LetsEncrypt container in the docker compose file with the rest of the containers?
Hi Guys,
im a bit stumped, lets encrypt and node red containers wont start cause something is using their ports
ERROR: for letsencrypt Cannot start service letsencrypt: driver failed programming external connectivity on endpoint letsencrypt (66acdfad8737d0259b89808b474dab50e0cb1b596c755e4265973835e31fb0e7): Error starting userland proxy: listen tcp 0.0.0.0:443: bind: address already in use
When I run netstat -tulpn I can see something using both those ports but not what. They are also IPV6 addresses but there isnt anything using the ports on IP4.
