I’m brand new to everything, so my apologies in advance for the incorrect terminology and confusion.
I installed Ubuntu on a clean ssd in an i5, then installed HASS Core in a docker container.
It’s running nicely.
I would like to use some devices that require ESPHome.
My understanding is the HASS Core in Docker will not permit use of the ESPHome HA Add-On, right?
But, I can still run ESPHome on the machine.
I installed ESPHome and running: “Sudo docker images” and Sudo docker ps" both show both esphome/esphome as well as home-assistant.
And, I can run the esphome wizard to create .yaml files.
That’s as far as I’ve gotten.
I don’t have the esp hardware yet, but I wanted to be ready for it.
I really have no clue how to next proceed. I tried to install the HA integration and it wants a host and port. When I put in 192.168.1.193 and 6053 I get:
Can’t connect to ESP. Please make sure your YAML file contains an ‘api:’ line.
What should I do next?
Thanks!
