Hi!
Just installed my first HA instance on a VM (vrit-manager) on Ubuntu. Everything works fine until I noticed I cant access it from other Network pc. Tried a lot of things on my own (as i basically dont know linux!) and couldnt fix the problem. I follow recommandation to use Nabu Casa instead so I have no problem accessing HA from anywhere now.
But, I still have issue and it looks it all comes to the same original ip configuration and network problem.
Exemple 1 : HA cant access to my Chromecast
Exemple 2 : Can’t install add-on (throught Nabu) and got a message there’s no internet connection
Exemple 3 : Can’t use HA app (android phone) cause he cant access the VM
Question a) Is my problem all related to the same issue and could be fix by setting the VM ip adresse the same as other in the network?
Question b) Is there a simplier way to install HA without having to learn all the linux and networking basics on top of it?
Question c) If the best solution for me is fixing my network/vm problem, any link for a complete step-by-step to do so?
Thanks a lot!
