UDP support
Hi! I have some powersupplay kwr 102 with udp control. Can you add UDP support like tcp support?
I wanted UDP support a while ago and there are many posts on here about it, not sure if it ever got implemented. I ended up using NodeRed as that has UDP built in
Thx for NodeRed ! It is very good software. But i cant use UDP ports on the addons. It is not goto outside. Ha install on docker used Supervised. How can i uses UDP ports?
Not sure sorry I use haos
