I have an HTTP(s) server with Apache and I have a Raspeberry Pi4 2GB with HassOS 4.17.
On my HTTP(s) server (debian based) I use UFW and I configure Apache for reverse proxy from my subdoman but inside syslog UFW block incoming packages from HassOS (192.168.1.25) and my server (192.168.1.6).
My configuration:
UFW
Status: active
Logging: on (low)
Default: deny (incoming), allow (outgoing), disabled (routed)
New profiles: skip
To Action From
80/tcp ALLOW IN Anywhere
443/tcp ALLOW IN Anywhere
22/tcp ALLOW IN 192.168.1.0/24
8883/tcp ALLOW IN Anywhere
Anywhere ALLOW IN 192.168.1.25
80/tcp (v6) ALLOW IN Anywhere (v6)
443/tcp (v6) ALLOW IN Anywhere (v6)
8883/tcp (v6) ALLOW IN Anywhere (v6)
UFW Logs:
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47052 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47204 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47472 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47678 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47604 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47774 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47830 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47920 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47914 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=48060 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=48256 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=48194 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47010 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=48474 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=47014 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=48748 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=46690 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=48324 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=46688 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=38576 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=48968 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=48932 WINDOW=0 RES=0x00 RST URGP=0
[UFW BLOCK] IN=eth0 OUT= MAC=5e:6f:fe:92:16:4d:dc:a6:32:34:12:48:08:00 SRC=192.168.1.25 DST=192.168.1.6 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=8123 DPT=49228 WINDOW=0 RES=0x00 RST URGP=0
Apache Reverse Proxy config:
<VirtualHost *:80>
ServerName hassos.mydomain.tk
ServerSignature Off
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule .* https://%{SERVER_NAME}%{REQUEST_URI} [NE,R,L]
ErrorLog ${APACHE_LOG_DIR}/IoT/error.log
CustomLog ${APACHE_LOG_DIR}/IoT/access.log combined
</VirtualHost>
<IfModule mod_ssl.c>
<VirtualHost *:443>
ProxyPreserveHost On
ProxyRequests Off
ProxyPass /api/websocket ws://192.168.1.25:8123/api/websocket
ProxyPassReverse /api/websocket ws://192.168.1.25:8123/api/websocket
ProxyPass / http://192.168.1.25:8123/
ProxyPassReverse / http://192.168.1.25:8123/
RewriteEngine on
RewriteCond %{HTTP:Upgrade} =websocket [NC]
RewriteRule /(.*) ws://192.168.1.25:8123/$1 [P,L]
RewriteCond %{HTTP:Upgrade} !=websocket [NC]
RewriteRule /(.*) http://192.168.1.25:8123/$1 [P,L]
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/hassos.mydomain.tk/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/hassos.mydomain.tk/privkey.pem
</VirtualHost>
</IfModule>
