since half a year my Hass is acting weirdly and hangs after several days. First assumed a hardware error so upgraded to a fast intel NUC.
I also suspected a custom component or something in my config. But now i have most things turned of in my config except:
- zwave (only switches and 1 binary sensor)
- ip cam
- telegram
What happens:
- automation are not run anymore
- the UI website won’t open anymore
But:
- i have a walltablet with the UI open, i can’t reload a TAB, but when i manually do a ZWave switch, the status is still updated in the UI
- the Zwave log + DB keep increasing in data and date modified.
- the .log file doesn’t showing anthing useull what should cause the hang of Hass;
- disconnected my router and, in the .log was this added:
2018-10-02 19:22:49 ERROR (MainThread) [homeassistant.components.telegram_bot.polling] Cannot connect to host api.telegram.org:443 ssl:None [Temporary failure in name resolution]
So the program is still running but:
- UI not accessible, automations are not processed, log file does not show anything special.
How to debug this? Annoying me for some time, but always just did a reboot/container restart.
Can i get more info in the log??
