I’m having trouble explaining this issue, and after searching online, I haven’t found anyone with the same problem. When I try to create an automation or script, selecting options from the UI no longer shows the user-friendly interface it used to have. Instead, I’m forced to use YAML…
Let me show you a screenshot to better explain what I mean:
The same happen on web! I tried with Chrome, Firefox or Safari. Tried to clear the cache, cookies… same problem. And this doesn’t happen only with “buttons” but with many other trigger/options.
I’m really the only one? How can I get out from this situation?
No your not the only one! I cant help resolve but ive had this since 2024.09 i think, has gotten worse with 10/11.
I need to get time to see if booting in safe mode resolves it. Theres an issue open about it on ths frontend github but there wasn’t a resolution from last time i checked.
For me it affects some custom integrations, adaptive-lighting and wiser for example but others are fine like spook. Theres also a lot of conditions that dont show, and some actions from core stuff.
