I’ve slowly been switching from using solely YAML files for automation and scripts to the UI. This has mostly worked without issue but I can across a slightly odd one yesterday. My wakeup script fires off a light on, an alexa media notify with a custom message payload, an alexa media play sequence and then an alexa media play apple music. The alexa media notify is not working, and the error message I get is;
Wakeup Luke: Error executing script. Invalid data for call_service at pos 4: extra keys not allowed @ data['media_content_id']
In the wakeup script the Alexa calendar play sequence looks like this;
- data:
media_content_id: Alexa.Calendar.PlayToday
media_content_type: sequence
entity_id: media_player.bedroom_dingus
service: media_player.media_play
However I have created a standalone test for this which works fine and it shows the exact same yaml;
- data:
entity_id: media_player.study_dingus
service: media_player.play_media
Both automation modes are single. I thought that maybe the notify one was causing an issue as there are lots of sensor values in there, but even when I moved the Calendar one before the Notify one the Calendar one failed and the Notify worked. For refence, here is the full YAML;
wakeup_luke:
alias: Wakeup Luke
icon: mdi:alarm-check
mode: single
sequence:
- data:
brightness_pct: 1
entity_id: light.bedroom_light
service: light.turn_on
- data:
type: tts
message: 'Good {{ states(''sensor.time_of_day'')}} Luke, it is {% set timestamp
now().strftime(''%I %M %p'') %}{{ timestamp.lstrip("0") }} on {{
as_timestamp(now()) | timestamp_custom(''%A'') }} the {{
states(''sensor.date_human'') }} of {{ as_timestamp(now()) |
timestamp_custom(''%B'') }}. You {% if states(''calendar.work'') == ''on''
or
states(''binary_sensor.workday_sensor'') == ''off'' or
states(''binary_sensor.working_from_home_luke'') == ''off'' -%} are not working
{%- else -%} are working from home {%- endif %} today. The temperature outside
feels like {{ states(''sensor.dark_sky_apparent_temperature'')}} degrees.
Your
indoor temperature is {{ state_attr(''climate.heating'', ''current_temperature'')
}} degrees. The forecast for today is {{
states(''sensor.dark_sky_hourly_summary'') }} with a {{
states(''sensor.dark_sky_precip_probability'') }} percent chance of rain for
the
hour. You have {{ states(''sensor.annual_leave'')}} days of Annual Leave
remaining.'
target: media_player.bedroom_dingus
service: notify.alexa_media
- delay: 00:00:45
- data:
- delay: 00:00:45
- data:
media_content_id: Outside In
media_content_type: APPLE_MUSIC
