Hello everybody,
I just started playing around with Home Assistant for a few days. Before I was using OpenHAB for a while. I’m running Home Assistant, Zigbee2MQTT and mosquitto in separate containers on a Raspi based NAS. I managed to integrate a bunch of devices and successfully setup several automations – so far so good…
Now I stumbled over a problem where I can’t find an answer. This is my 1st post in this forum – hope my question is not too stupid
I’ve two color light bulbs – one from Ikea and one from Lidl. Both seem to work fine. Using the device control UI I can change the color and color temp for both bulbs without problems.
I’d like to create an automation that switches a bulb on and that sets color and color temp. I’m using the service “Light: Turn On”. I can select the bulb as device or entity, and I can set the brightness – works fine. But when I check color or color temp the UI does not offer any picker for color or color temp?!? Am I doing something wrong here?
But help is near:
