UI errors on Firefox Quantum
I’m using firefox 58.0.2 and each time I try to close an open panel clicking outside it home-assistant logs this:
2018-02-20 10:34:09 ERROR (MainThread) [frontend.js.latest.201802090] data:text/javascript;charset=utf-8,!function()%7B%22use%20strict%22%3Bconst%20e%3DElement.prototype%2Ct%3De.matches%7C%7Ce.matchesSelector%7C%7Ce.mozMatchesSelector%7C%7Ce.msMatchesSelector%7C%7Ce.oMatchesSelector%7C%7Ce.webkitMatchesSelector%2Co%3Dfunction(e%2Co)%7Breturn%20t.call(e%2Co)%7D%3Bclass%20r%7Bconstructor(e)%7Bthis.node%3De%7DobserveNodes(e)%7Breturn%20new%20Polymer.FlattenedNodesObserver(this.node%2Ce)%7DunobserveNodes(e)%7Be.disconnect()%7DnotifyObserver()%7B%7DdeepContains(e)%7Bif(this.node.contains(e))return!0%3Blet%20t%3De%2Co%3De.ownerDocument%3Bfor(%3Bt%26%26t!%3D%3Do%26%26t!%3D%3Dthis.node%3B)t%3Dt.parentNode%7C%7Ct.host%3Breturn%20t%3D%3D%3Dthis.node%7DgetOwnerRoot()%7Breturn%20this.node.getRootNode()%7DgetDistributedNodes()%7Breturn%22slot%22%3D%3D%3Dthis.node.localName%3Fthis.node.assignedNodes(%7Bflatten%3A!0%7D)%3A%5B%5D%7DgetDestinationInsertionPoints()%7Blet%20e%3D%5B%5D%2Ct%3Dthis.node.assignedSlot%3Bfor(%3Bt%3B)e.push(t)%2Ct%3Dt.assignedSlot%3Breturn%20e%7DimportNode(e%2Ct)%7Breturn(this.node%20instanceof%20Document%3Fthis.node%3Athis.node.ownerDocument).importNode(e%2Ct)%7DgetEffectiveChildNodes()%7Breturn%20Polymer.FlattenedNodesObserver.getFlattenedNodes(this.node)%7DqueryDistributedElements(e)%7Blet%20t%3Dthis.getEffectiveChildNodes()%2Cr%3D%5B%5D%3Bfor(let%20n%2Ci%3D0%2Cl%3Dt.length%3Bi%3Cl%26%26(n%3Dt%5Bi%5D)%3Bi%2B%2B)n.nodeType%3D%3D%3DNode.ELEMENT_NODE%26%26o(n%2Ce)%26%26r.push(n)%3Breturn%20r%7Dget%20activeElement()%7Blet%20e%3Dthis.node%3Breturn%20void%200!%3D%3De._activeElement%3Fe._activeElement%3Ae.activeElement%7D%7D!function(e%2Ct)%7Bfor(let%20o%3D0%3Bo%3Ct.length%3Bo%2B%2B)%7Blet%20r%3Dt%5Bo%5D%3Be%5Br%5D%3Dfunction()%7Breturn%20this.node%5Br%5D.apply(this.node%2Carguments)%7D%7D%7D(r.prototype%2C%5B%22cloneNode%22%2C%22appendChild%22%2C%22insertBefore%22%2C%22removeChild%22%2C%22replaceChild%22%2C%22setAttribute%22%2C%22removeAttribute%22%2C%22querySelector%22%2C%22querySelectorAll%22%5D)%2Cfunction(e%2Ct)%7Bfor(let%20o%3D0%3Bo%3Ct.length%3Bo%2B%2B)%7Blet%20r%3Dt%5Bo%5D%3BObject.defineProperty(e%2Cr%2C%7Bget%3Afunction()%7Breturn%20this.node%5Br%5D%7D%2Cconfigurable%3A!0%7D)%7D%7D(r.prototype%2C%5B%22parentNode%22%2C%22firstChild%22%2C%22lastChild%22%2C%22nextSibling%22%2C%22previousSibling%22%2C%22firstElementChild%22%2C%22lastElementChild%22%2C%22nextElementSibling%22%2C%22previousElementSibling%22%2C%22childNodes%22%2C%22children%22%2C%22classList%22%5D)%2Cfunction(e%2Ct)%7Bfor(let%20o%3D0%3Bo%3Ct.length%3Bo%2B%2B)%7Blet%20r%3Dt%5Bo%5D%3BObject.defineProperty(e%2Cr%2C%7Bget%3Afunction()%7Breturn%20this.node%5Br%5D%7D%2Cset%3Afunction(e)%7Bthis.node%5Br%5D%3De%7D%2Cconfigurable%3A!0%7D)%7D%7D(r.prototype%2C%5B%22textContent%22%2C%22innerHTML%22%5D)%3Bclass%20n%7Bconstructor(e)%7Bthis.event%3De%7Dget%20rootTarget()%7Breturn%20this.event.composedPath()%5B0%5D%7Dget%20localTarget()%7Breturn%20this.event.target%7Dget%20path()%7Breturn%20this.event.composedPath()%7D%7DPolymer.DomApi%3Dr%2CPolymer.DomApi.prototype.cloneNode%2CPolymer.DomApi.prototype.appendChild%2CPolymer.DomApi.prototype.insertBefore%2CPolymer.DomApi.prototype.removeChild%2CPolymer.DomApi.prototype.replaceChild%2CPolymer.DomApi.prototype.setAttribute%2CPolymer.DomApi.prototype.removeAttribute%2CPolymer.DomApi.prototype.querySelector%2CPolymer.DomApi.prototype.querySelectorAll%2CPolymer.dom%3Dfunction(e)%7Bif(!(e%3De%7C%7Cdocument).__domApi)%7Blet%20t%3Bt%3De%20instanceof%20Event%3Fnew%20n(e)%3Anew%20r(e)%2Ce.__domApi%3Dt%7Dreturn%20e.__domApi%7D%2CPolymer.dom.matchesSelector%3Do%2CPolymer.dom.flush%3DPolymer.flush%2CPolymer.dom.addDebouncer%3DPolymer.enqueueDebouncer%7D()%3B%0A%2F%2F%23%20sourceURL%3Dhttps%3A%2F%2FOMISSIS%3A8123%2Ffrontend_latest%2Ffrontend-ebcb41952b21503c6a09065b084a638d.html-29.js%0A:0:0 Script error.
No error on Chrome or Safari, same wrong behaviour on Firefox on Windows and Mac Os. I’m able to close the panel with esc.
Does anybody have the same behaviour? I couldn’t find any similar post in the community.
Add
frontend:
  javascript_version: auto
To your configuration.yaml.
Thank you. I did it, no luck: same error in the logs.
Obviously I cleaned the firefox cache e forced refresh.
Firefox seems to be a lot less tollerant of script errors. It simply refuses to render the page where as Chrome and iOS will still attempt to. They all still write to the error log though.
If you have a look at your error log in Chrome (after loading the page and clicking outside the panel in Chrome) you might find there is still an errror generated and it may be a bit easier to read. At last that was the case with a script error I had yesterday.
Hi tom_I,
i tried back with Chrome and no errors are logged.
Ah well, that’s about the extent of the help I can offer unfortunately. I’ve only been at this for a few days. Good luck.
Thank you anyway, I’ll wait for some other feedback hoping it’s only my issue.
Looking for some opened issue before filing mine I found issue #12122
Let’s hope it will be fixed even if no one is still assigned to it.
