Mar 22 21:53:06 pi hass[28675]: 2020-03-22 21:53:06 ERROR (MainThread) [homeassistant.config] Invalid config for [lovelace]: [resources] is an invalid option for [lovelace]. Check: lovelace->lovelace->resources. (See /home/homeassistant/.homeassistant/configuration.yaml, line 6). Please check the docs at https://www.home-assistant.io/integrations/lovelace
Mar 22 21:53:06 pi hass[28675]: 2020-03-22 21:53:06 ERROR (MainThread) [homeassistant.setup] Setup failed for lovelace: Invalid config.
Seems valid when reading this:
Also, is the /local/ reference, a ref to www in HA config dir (which for me is /home/homeassistant/.homeassistant/www) where my simple-thermostat.js resides?
That is only true if you are using v106 or earlier.
The location of the resources has changed starting in v107. They will now be added to the lovelace: section of configuration.yaml as you originally had it.
If you update be prepared for things not to work again until you fix it.
Ah - ok.
I wish the devs would not break previous working functionality - it’s a rather frustrating “upgrade” feature. If that’s going to happen, then - as indeed we do in our software house - provide an upgrade tool , or better , resolve obsolescence as part of the upgrade.
But then again, it is FOSS .
@finity: I have the same erro.
Please can you explain this “They will now be added to the lovelace: section of configuration.yaml as you originally had it.”
the person i was responding to said the resources section needed to be in the ui-lovelace.yaml file. but i clarified that was only true on HA version 106 and earlier. In v107 the location changed to the location noted above.
