UI lag with lights in Home Assistant
I’m having trouble with dimmer ui lag in home assistant. I usually have to turn off dimmers twice to get them to show as off, and when adjusting the slider it always pops back to its previous setting (all commands actually go through to the lights though, it just doesn’t appear in the ui). You can see it in this video: https://youtu.be/6aIwQ2f5oIg?t=8m53s . Is this common and is there some workaround to fix it? I’m using the same switches in the video by the way (Homeseer wd-100+ z-wave plus with instant status)
