I’m trying to switch to using ui-lovelace.yaml and am getting lots of “red block” errors due to missing resources, such as auto-entities, which were installed via HACS.
I’ve tried adding this block (and variations with different paths) to the beginning ui-lovelace.yaml, with no success. I assume this is a simple issue, what do I need to do?
resources:
- type: module
url: /www/community/battery-entity-row.js?v=1.0.0
- type: module
url: /www/community/lovelace-card-tools/card-tools.js
- type: module
url: /www/community/weather-card/weather-card.js
- type: module
url: /www/community/simple-thermostat/simple-thermostat.js
- type: module
url: /www/community/lovelace-card-mod/card-mod.js
- type: module
url: /www/community/lovelace-fold-entity-row/fold-entity-row.js
- type: module
url: /www/community/lovelace-auto-entities/auto-entities.js
- type: js
url: /www/community/iCloud3/icloud3-event-log-card.js?v=1.000
- type: module
url: /www/community/lovelace-gui-sandbox/gui-sandbox.js
finity
October 29, 2020, 11:01pm
2
The resources no longer go in ui-lovelace.yaml.
they now go under the “lovelace:” section of configuration.yaml:
lovelace:
mode: yaml
resources:
- type: module
- type: module
- type: module
This is what I used:
lovelace:
mode: yaml
resources:
- type: module
url: /www/community/lovelace-battery-entity-row/battery-entity-row.js?v=1.0.0
- type: module
- type: module
- type: module
- type: module
- type: module
- type: module
And I’m getting these errors
And this is what my file structure looks like.
I assume HACS installed these folders in /www/community. Am I using the correct paths in my resources sections? Do I need to grant permissions somewhere?
I went and reinstalled one of the integrations and the install gave me some advice. Here is what I ended up with
lovelace:
mode: yaml
resources:
- type: module
url: /hacsfiles/lovelace-fold-entity-row/fold-entity-row.js
- type: module
url: /hacsfiles/lovelace-auto-entities/auto-entities.js
- type: module
url: /hacsfiles/lovelace-battery-entity-row/battery-entity-row.js
- type: module
url: /hacsfiles/lovelace-card-tools/card-tools.js
- type: module
url: /hacsfiles/lovelace-card-mod/card-mod.js
- type: module
url: /hacsfiles/simple-thermostat/simple-thermostat.js
- type: module
url: /hacsfiles/weather-card/weather-card.js
- type: module
url: /hacsfiles/lovelace-layout-card/layout-card.js
Thanks!
finity
October 30, 2020, 1:16pm
5
Yeah, sorry. I should have caught that “www/” in the path.
that would never have worked. The “simlink” (or whatever it’s called in this case) for the “www” folder is “local”.
So in your example even if you didn’t use HACS the entry should have been like “url: /local/community/weather-card/weather-card.js”.
Do you know how !includes work for ui-lovelace.yaml?
I have an integration which generates a lovelace “view” file in the package/myintegration/foobar.txt
I want to include that into ui-lovelace.yaml. I know I can copy it into /config/lovelace/foobar.txt, but my aim is to not have to, so when my integration options change the view changes appear automatically. Any advice?
finity
October 30, 2020, 8:55pm
7
the includes work just like they do in the main config.
I believe you can put them anywhere you want as long they are referenced correctly in ui-lovelace.yaml.
I have all of my views located in, for example, “/config/lovelace_views/my_view.yaml”
then I reference it in ui-lovelace.yaml like:
title: Home Assistant
- !include '/config/lovelace_views/my_view.yaml'
- !include '/config/lovelace_views/my_other_view.yaml'
so you should be able to add it:
- !include '/config/package/myintegration/foobar.yaml
I’m assuming it’s referenced somewhere as a yaml file?
And you need to make sure to whitelist the directory location.
in mine it’s like:
homeassistant:
allowlist_external_dirs:
- '/config/lovelace_views'
