Hey all,
Forgive my lamens terms, not a developer and want to try and see what I can achieve.
I am using Mushroom UI and think it is a fantastic way for beginners, and non dev types to build wonderful dashboards BUT I want more
In Minimalist UI they have a Welcome card with 5 switches that I would like to utilise. I have uploaded the template to: /config/ui_lovelace_minimalist/custom_cards/card_esh_welcome/card_esh_welcome.yaml
If you want to use Minimalist in UI mode you have to copy the button card templates into the raw config. You can also choose a mixes yaml / storage mode.; in this case you are able to build a Minimalist dashboard in yaml parallel to other dashboards that can be configured via UI. As far as I remember, Minimalist has an excellent documentation. Have a look at it
If you want the mushroom look in the ui, you shouldn’t use ui minimalist. You shook look into mushroom cards, which is beginner friendly. I’ll find the link to it.
