i got an xx.js-error displaying the supervisor page in the UI recently, everything else worked.
tried a reboot through the UI - did not reboot
took off the power of the pi, turned it back on and cannot connect to the ui at all
tried to ssh to the pi - get an “connection refused”. The pi is having a red led constant on (after some red/green flickering what happens after repowering, network is flickering and i can see the ip in the network
Some idea what was/is happening here? And more importantly, what i can do about it?
Thank you very much in advance!
If you haven’t already solved the problem or set up a fresh HA:
When you’re in this CLI, running ‘core check’ might help.
From the description it should only check the core configuration, but running it solved an unavailable UI for me once.
Thank you, eventually got to this point.
Checked, updated and checked again to no avail.
I decided to go the extra step and set it up as a new one and copy things from an old backup i had. This way i got rid of a lot of old and now useless stuff… Maybe it was for the better.
