Hi team…
I have a 2 gang zigbee switch module which I believe should be able to be wired up with a 2 way landing light setup in the uk…
and the module itself…
What I am struggling with this, is the wiring. This is just a single light with two switches operating it. Why are there so many live lines in this setup? Any help with what I am feeding into the module and out to the switch?
No. Your belief will get you killed. 2 gang and 2 way are different things.
You bought a 2 gang, 1 way controller, but you have a 1 gang, 2 way controller. Those two things are not the same. Please close up that light switch and call an electrician who has some experience with installing smart home modules.
Yes, I know this post sounds harsh, but I’d rather have you being mad at me than injured or worse.
Please refer to the manual, that’s an extra gang that you don’t need anyway
You’ll need another live cable going to the relay, similar to this wiring
