Can anyone recommend some UK style bayonet RGB Wifi bulbs, that can be intergrated relatively easily to a hassio setup.
These are for my daughters house, where her and the son-in-law just want to a couple of RGB lights with remotes, and phone controll. However I know once they’ve done that, it’s only a few small steps to a raspberry pi and HASSIO
Ideally given the use something that doesn’t need taking apart to reflash etc. would be good.
LIFX work pretty well.
I used to use them by themselves with my phone to control them. Or Alexa.(Or flic with bluetooth via my phone) Or a cronjob on a server to make them flash red once an hour via their api.
(I’ve not used them with Home Assistant, due to moving house to somewhere without suitable sockets)
As a longer term solution I would recommend to “upgrade” to E27 fixtures as there is so much more choice, and hence lower prices.
I am slowly replacing all the pendent fixtures in my home from B22 to E27.
Just did the master bedroom this weekend as the shade was being replaced.
So if we used a E27 bulb, what would the recommendations be? Again ideally given the use something that doesn’t need taking apart to reflash etc. would be good.
So for 6 RGB bulbs spread throughout the house, with a remote in each room. Do I need one gateway, or will I need to space them around the house. Distances aren’t too bad, fairly compact 3 bed house.
Hmm, Wifi signal is good all round the house, but it 's a mesh network. My guess is it would be alright as controlling a light is not exactly going to be like streaming a 4k film lol.
