For the UK folk - you might not know that there is a defined schedule for emergency power cuts with areas and time periods. You can find out what area you are in on your electricity bill - it will be a letter in a square box (A - U).
There are 18 severity levels of power cuts, Level 1 is typically a few power cuts per week right up to Level 18 which is the entire National Grid is down.
You can find out more information here: https://www.nationalgrideso.com/document/13121/download
Now on to the project:
I created this JSON file, by manually entering the data from the PDF in to a spreadsheet, saving as CSV and then writing some PHP code to turn it into a nice and easy to use JSON file. Here is the file:
{"day":{"1":{"period":{"1":{"level":{"1":"A","2":"B","3":"C","4":"H","5":"T","6":"N","7":"L","8":"M","9":"K","10":"G","11":"J","12":"R","13":"D","14":"S","15":"P","16":"E","17":"U","18":"Q"}},"2":{"level":{"1":"D","2":"E","3":"G","4":"J","5":"U","6":"R","7":"P","8":"Q","9":"T","10":"A","11":"K","12":"L","13":"B","14":"H","15":"M","16":"C","17":"S","18":"N"}},"3":{"level":{"1":"B","2":"C","3":"A","4":"K","5":"S","6":"L","7":"M","8":"N","9":"J","10":"E","11":"T","12":"P","13":"G","14":"U","15":"Q","16":"D","17":"H","18":"R"}},"4":{"level":{"1":"E","2":"G","3":"D","4":"H","5":"T","6":"P","7":"Q","8":"R","9":"U","10":"B","11":"S","12":"M","13":"C","14":"J","15":"N","16":"A","17":"K","18":"L"}},"5":{"level":{"1":"C","2":"A","3":"B","4":"J","5":"U","6":"M","7":"N","8":"L","9":"S","10":"D","11":"H","12":"Q","13":"E","14":"K","15":"R","16":"G","17":"T","18":"P"}},"6":{"level":{"1":"G","2":"D","3":"E","4":"K","5":"S","6":"Q","7":"R","8":"P","9":"H","10":"C","11":"U","12":"N","13":"A","14":"T","15":"L","16":"B","17":"J","18":"M"}},"7":{"level":{"1":"B","2":"H","3":"T","4":"L","5":"A","6":"M","7":"K","8":"G","9":"J","10":"R","11":"D","12":"S","13":"P","14":"E","15":"U","16":"Q","17":"C","18":"N"}},"8":{"level":{"1":"C","2":"J","3":"U","4":"N","5":"K","6":"S","7":"T","8":"A","9":"L","10":"B","11":"H","12":"M","13":"E","14":"P","15":"G","16":"Q","17":"D","18":"R"}}}},"2":{"period":{"1":{"level":{"1":"E","2":"G","3":"D","4":"A","5":"M","6":"P","7":"Q","8":"R","9":"C","10":"K","11":"B","12":"U","13":"H","14":"L","15":"S","16":"J","17":"N","18":"T"}},"2":{"level":{"1":"H","2":"J","3":"K","4":"B","5":"N","6":"U","7":"S","8":"T","9":"M","10":"E","11":"C","12":"Q","13":"G","14":"A","15":"R","16":"D","17":"L","18":"P"}},"3":{"level":{"1":"G","2":"D","3":"E","4":"C","5":"L","6":"Q","7":"R","8":"P","9":"B","10":"J","11":"M","12":"S","13":"K","14":"N","15":"T","16":"H","17":"A","18":"U"}},"4":{"level":{"1":"J","2":"K","3":"H","4":"A","5":"M","6":"S","7":"T","8":"U","9":"N","10":"G","11":"L","12":"R","13":"D","14":"B","15":"P","16":"E","17":"C","18":"Q"}},"5":{"level":{"1":"D","2":"E","3":"G","4":"B","5":"N","6":"R","7":"P","8":"Q","9":"L","10":"H","11":"A","12":"T","13":"J","14":"C","15":"U","16":"K","17":"M","18":"S"}},"6":{"level":{"1":"K","2":"H","3":"J","4":"C","5":"L","6":"T","7":"U","8":"S","9":"A","10":"D","11":"N","12":"P","13":"E","14":"M","15":"Q","16":"G","17":"B","18":"R"}},"7":{"level":{"1":"E","2":"A","3":"N","4":"P","5":"D","6":"Q","7":"C","8":"K","9":"B","10":"U","11":"H","12":"L","13":"S","14":"J","15":"T","16":"M","17":"G","18":"R"}},"8":{"level":{"1":"G","2":"B","3":"M","4":"R","5":"C","6":"L","7":"E","8":"Q","9":"A","10":"D","11":"P","12":"J","13":"S","14":"K","15":"N","16":"T","17":"H","18":"U"}}}},"3":{"period":{"1":{"level":{"1":"J","2":"K","3":"H","4":"D","5":"Q","6":"S","7":"T","8":"U","9":"G","10":"A","11":"E","12":"L","13":"B","14":"P","15":"M","16":"C","17":"R","18":"N"}},"2":{"level":{"1":"B","2":"C","3":"A","4":"E","5":"R","6":"L","7":"M","8":"N","9":"Q","10":"J","11":"G","12":"T","13":"K","14":"D","15":"U","16":"H","17":"P","18":"S"}},"3":{"level":{"1":"K","2":"H","3":"J","4":"G","5":"P","6":"T","7":"U","8":"S","9":"E","10":"C","11":"Q","12":"M","13":"A","14":"R","15":"N","16":"B","17":"D","18":"L"}},"4":{"level":{"1":"C","2":"A","3":"B","4":"D","5":"Q","6":"M","7":"N","8":"L","9":"R","10":"K","11":"P","12":"U","13":"H","14":"E","15":"S","16":"J","17":"G","18":"T"}},"5":{"level":{"1":"H","2":"J","3":"K","4":"E","5":"R","6":"U","7":"S","8":"T","9":"P","10":"N","11":"D","12":"N","13":"C","14":"G","15":"L","16":"A","17":"Q","18":"M"}},"6":{"level":{"1":"A","2":"B","3":"C","4":"G","5":"P","6":"N","7":"L","8":"M","9":"D","10":"H","11":"R","12":"S","13":"J","14":"Q","15":"T","16":"K","17":"E","18":"U"}},"7":{"level":{"1":"H","2":"D","3":"R","4":"T","5":"J","6":"S","7":"G","8":"A","9":"E","10":"L","11":"B","12":"P","13":"M","14":"C","15":"N","16":"K","17":"U","18":"Q"}},"8":{"level":{"1":"K","2":"E","3":"Q","4":"U","5":"G","6":"P","7":"J","8":"T","9":"D","10":"H","11":"S","12":"C","13":"M","14":"A","15":"R","16":"N","17":"B","18":"L"}}}},"4":{"period":{"1":{"level":{"1":"L","2":"M","3":"N","4":"S","5":"J","6":"C","7":"A","8":"B","9":"U","10":"R","11":"T","12":"G","13":"P","14":"H","15":"D","16":"Q","17":"K","18":"E"}},"2":{"level":{"1":"P","2":"Q","3":"R","4":"T","5":"K","6":"G","7":"D","8":"E","9":"J","10":"L","11":"U","12":"A","13":"M","14":"S","15":"B","16":"N","17":"H","18":"C"}},"3":{"level":{"1":"M","2":"N","3":"L","4":"U","5":"H","6":"A","7":"B","8":"C","9":"T","10":"Q","11":"J","12":"D","13":"R","14":"K","15":"E","16":"P","17":"S","18":"G"}},"4":{"level":{"1":"Q","2":"R","3":"P","4":"S","5":"J","6":"D","7":"E","8":"G","9":"K","10":"M","11":"H","12":"B","13":"N","14":"T","15":"C","16":"L","17":"U","18":"A"}},"5":{"level":{"1":"N","2":"L","3":"M","4":"T","5":"K","6":"B","7":"C","8":"A","9":"H","10":"P","11":"S","12":"E","13":"Q","14":"U","15":"G","16":"R","17":"J","18":"D"}},"6":{"level":{"1":"R","2":"P","3":"Q","4":"U","5":"H","6":"E","7":"G","8":"D","9":"S","10":"N","11":"K","12":"C","13":"L","14":"J","15":"A","16":"M","17":"T","18":"B"}},"7":{"level":{"1":"M","2":"S","3":"J","4":"A","5":"L","6":"B","7":"U","8":"R","9":"T","10":"G","11":"P","12":"H","13":"D","14":"Q","15":"K","16":"E","17":"N","18":"C"}},"8":{"level":{"1":"N","2":"T","3":"K","4":"C","5":"U","6":"H","7":"J","8":"L","9":"A","10":"M","11":"S","12":"B","13":"Q","14":"D","15":"R","16":"E","17":"P","18":"G"}}}},"5":{"period":{"1":{"level":{"1":"Q","2":"R","3":"P","4":"L","5":"B","6":"D","7":"E","8":"G","9":"N","10":"U","11":"M","12":"K","13":"S","14":"A","15":"H","16":"T","17":"C","18":"J"}},"2":{"level":{"1":"S","2":"T","3":"U","4":"M","5":"C","6":"K","7":"H","8":"J","9":"B","10":"Q","11":"N","12":"E","13":"R","14":"L","15":"G","16":"P","17":"A","18":"D"}},"3":{"level":{"1":"R","2":"P","3":"Q","4":"N","5":"A","6":"E","7":"G","8":"D","9":"M","10":"T","11":"B","12":"H","13":"U","14":"C","15":"J","16":"S","17":"L","18":"K"}},"4":{"level":{"1":"T","2":"U","3":"S","4":"L","5":"B","6":"H","7":"J","8":"K","9":"C","10":"R","11":"A","12":"G","13":"P","14":"M","15":"D","16":"Q","17":"N","18":"E"}},"5":{"level":{"1":"P","2":"Q","3":"R","4":"M","5":"C","6":"G","7":"D","8":"E","9":"A","10":"S","11":"L","12":"J","13":"T","14":"N","15":"K","16":"U","17":"B","18":"H"}},"6":{"level":{"1":"U","2":"S","3":"T","4":"N","5":"A","6":"J","7":"K","8":"H","9":"L","10":"P","11":"C","12":"D","13":"Q","14":"B","15":"E","16":"R","17":"M","18":"G"}},"7":{"level":{"1":"Q","2":"L","3":"C","4":"D","5":"P","6":"E","7":"N","8":"U","9":"M","10":"K","11":"S","12":"A","13":"H","14":"T","15":"J","16":"R","17":"G","18":"B"}},"8":{"level":{"1":"R","2":"M","3":"B","4":"G","5":"N","6":"A","7":"Q","8":"E","9":"L","10":"P","11":"D","12":"T","13":"H","14":"U","15":"C","16":"J","17":"S","18":"K"}}}},"6":{"period":{"1":{"level":{"1":"T","2":"U","3":"S","4":"P","5":"E","6":"H","7":"J","8":"K","9":"R","10":"L","11":"Q","12":"A","13":"M","14":"D","15":"B","16":"N","17":"G","18":"C"}},"2":{"level":{"1":"M","2":"N","3":"L","4":"Q","5":"G","6":"A","7":"B","8":"C","9":"E","10":"T","11":"R","12":"J","13":"U","14":"P","15":"K","16":"S","17":"D","18":"H"}},"3":{"level":{"1":"U","2":"S","3":"T","4":"R","5":"D","6":"J","7":"K","8":"H","9":"Q","10":"N","11":"E","12":"B","13":"L","14":"G","15":"C","16":"M","17":"P","18":"A"}},"4":{"level":{"1":"N","2":"L","3":"M","4":"P","5":"E","6":"B","7":"C","8":"A","9":"G","10":"U","11":"D","12":"K","13":"S","14":"Q","15":"H","16":"T","17":"R","18":"J"}},"5":{"level":{"1":"S","2":"T","3":"U","4":"Q","5":"G","6":"K","7":"H","8":"J","9":"D","10":"M","11":"P","12":"C","13":"N","14":"R","15":"A","16":"L","17":"E","18":"B"}},"6":{"level":{"1":"L","2":"M","3":"N","4":"R","5":"D","6":"C","7":"A","8":"B","9":"P","10":"S","11":"G","12":"H","13":"T","14":"E","15":"J","16":"U","17":"Q","18":"K"}},"7":{"level":{"1":"S","2":"P","3":"G","4":"H","5":"T","6":"K","7":"R","8":"L","9":"Q","10":"A","11":"M","12":"D","13":"B","14":"N","15":"C","16":"J","17":"U","18":"E"}},"8":{"level":{"1":"U","2":"Q","3":"E","4":"J","5":"R","6":"D","7":"T","8":"P","9":"K","10":"S","11":"H","12":"N","13":"B","14":"L","15":"G","16":"C","17":"M","18":"A"}}}},"7":{"period":{"1":{"level":{"1":"A","2":"B","3":"C","4":"L","5":"N","6":"M","7":"E","8":"G","9":"D","10":"Q","11":"R","12":"P","13":"K","14":"H","15":"J","16":"U","17":"S","18":"T"}},"2":{"level":{"1":"D","2":"E","3":"G","4":"P","5":"Q","6":"R","7":"J","8":"K","9":"H","10":"T","11":"U","12":"S","13":"N","14":"L","15":"M","16":"C","17":"A","18":"B"}},"3":{"level":{"1":"H","2":"J","3":"K","4":"S","5":"T","6":"U","7":"M","8":"N","9":"L","10":"B","11":"C","12":"A","13":"R","14":"P","15":"Q","16":"G","17":"D","18":"E"}},"4":{"level":{"1":"L","2":"M","3":"N","4":"A","5":"C","6":"B","7":"Q","8":"R","9":"P","10":"E","11":"G","12":"D","13":"U","14":"S","15":"T","16":"K","17":"H","18":"J"}},"5":{"level":{"1":"P","2":"Q","3":"R","4":"D","5":"E","6":"G","7":"T","8":"U","9":"S","10":"J","11":"K","12":"H","13":"C","14":"A","15":"B","16":"N","17":"L","18":"M"}},"6":{"level":{"1":"S","2":"T","3":"U","4":"H","5":"J","6":"K","7":"B","8":"C","9":"A","10":"M","11":"N","12":"L","13":"G","14":"D","15":"E","16":"R","17":"P","18":"Q"}},"7":{"level":{"1":"P","2":"E","3":"R","4":"C","5":"B","6":"A","7":"L","8":"G","9":"D","10":"Q","11":"N","12":"M","13":"K","14":"H","15":"J","16":"U","17":"S","18":"T"}}}}}}
I then wrote some PHP code that you can stick on a webserver to return some JSON that can be used to populate a sensor.
<?php
date_default_timezone_set("Europe/London");
ob_start();
$APP['area'] = "A";
$APP['period'] = -1;
$APP['level'] = 1;
$APP['debug'] = false;
if (isset($_GET['area'])) {
$q = $_GET['area'];
if (strlen($q) == 1) {
$APP['area'] = strtoupper($q);
if (isset($_GET['period'])) {
$q = $_GET['period'];
if (is_numeric($q) && (($q > 0 && $q < 9) || $q == -1)) {
$APP['period'] = $q;
} else {
if (isset($_GET['level'])) {
$q = $_GET['level'];
if (is_numeric($q) && ($q > 0 && $q < 19)) {
$APP['level'] = $q;
// load data
$data = json_decode(file_get_contents("./data/eso_schedule.json"),true);
// if we are looking for a period then we want to return a true or a false
if ($APP['period'] !== -1) {
$out['query']['area'] = $APP['area'];
$out['query']['period'] = $APP['period'];
$out['query']['level'] = $APP['level'];
$out['result'] = checkPeriod($APP['period']);
header("content-type: application/json");
echo json_encode($out);
exit;
$q = nextPeriod();
$out['result'] = $q;
$today = date('N');
$TS = mktime(0,0,0); //set timestamp to midnight today
$diff = 0;
if ($today < $q['day']) {
$diff = $q['day'] - $today;
} elseif ($today > $q['day']) {
$diff = $today + $q['day'];
if ($diff) { $TS = $TS + (86400 * $diff); } //add number of days to today
$p = explode(":",timePeriods($q['period'])); //get the hours and minutes of the start of the period
$d = mktime($p[0],$p[1],0,date('m',$TS),date('j',$TS),date('Y',$TS)); //create timestamp
$out['result']['timestamp'] = date('c',$d);
exit;
function checkPeriod($period) {
global $data, $APP;
$day = date('N');
$f = false;
$i = 1;
while ($i < $APP['level'] + 1) {
if ($data['day'][$day]['period'][$period]['level'][$i] == $APP['area']) {
$f = true;
break;
$i++;
return $f;
function nextPeriod() {
global $APP, $data;
$data['day'][8] = $data['day'][1];
$data['day'][9] = $data['day'][2];
$data['day'][10] = $data['day'][3];
$data['day'][11] = $data['day'][4];
$data['day'][12] = $data['day'][5];
$data['day'][13] = $data['day'][6];
$data['day'][14] = $data['day'][7];
$today = date('N');
$f = false;
$i = $today;
while($i < 14) { // days
$p = 1;
while ($p < 9) { //periods
$l = 1;
while ($l < $APP['level'] + 1) { // levels
if ($data['day'][$i]['period'][$p]['level'][$l] == $APP['area']) {
$f = true;
break;
if ($APP['debug']) {
echo "\nDay: {$i}, Period: {$p}, Level: {$l} == {$data['day'][$i]['period'][$p]['level'][$l]}";
$l++;
if ($f) {
break;
$p++;
if ($f) {
break;
$i++;
if ($i > 7) { $i = $i - 7; }
$ret['day'] = $i;
$ret['period'] = $p;
$ret['level'] = $l;
return $ret;
function timePeriods($period) {
$p =
"06:30",
"09:30",
"12:30",
"15:30",
"18:30",
"21:30",
"00:30",
"03:30",
return $p[$period-1];
The way I use this: I am in Area A, and for now at least I am interested in level 1 disconnections. So I would use https://my-server-name/eso_schedule.php?area=a&level=1
as the REST resource and I would receive something back like:
{"query":{"area":"A","level":"1"},"result":{"day":3,"period":6,"level":1,"timestamp":"2022-10-26T21:30:00+01:00"}}
which tells me that IF they have to implement the emergency power cuts, my next one would be scheduled tomorrow (Wednesday 26th) at 9:30pm.
Yes it’s annoying that we might actually need this information over this winter, but I have done the hard work for you, so at least you can be prepared.
Note:
Because the schedule is done on increasing levels of severity, if I looked for a level 8 severity:
eso_schedule.php?area=a&level=8
You will notice that in the result:
{"query":{"area":"A","level":"8"},"result":{"day":"2","period":1,"level":4,"timestamp":"2022-10-25T06:30:00+01:00"}}
It says level 4 - because in this time period it will be a scheduled powercut from level 4 right through to level 18
