Hi, does anyone have any suggestions for a 6 way gang UK plug with usb c and usb a that works with zha
Sadly, I’ve never seen a 6x, and especially not off the shelf.
The closest was a batch of 4x way plus USB-A 2x (hacked with Tasmota or ESPhome), but these days the ESP8266 have been replaced with Tuya microcontrollers. Some of these can be converted to local ESPhome, but you likely need some electronics skills.
Blakadder’s database of kit for conversion is pretty good, but suffers from the same issue where a batch changes to save $0.05 and the internals change.
There are several bare-bones ESP8* relay boards out there in 4x, but 6x is likely to have a random undocumented port expander on the PCB, and that’s before you add a case and connectors.
