UK Light Switches *with a neutral*
All, I know that this topic has been done to death but I appear to have a neutral in my UK 4 gang light switch.
Would anyone mind expressing their expertise on this photo and let me know if the Sonoff Mini might work?
Looks like the blue cables have a brown sleeve, as do some of the grey, which suggests these can be live.
IF there is a neutral loop at the switch, these are normally tied together and NOT terminated at the switch itself. Normally in choc block.
I have had two UK houses (Scotland) with neutrals available at the switch.
If you do not know what you are doing, I suggest you leave well alone.
for an example see
https://www.flameport.com/electric/lighting_circuits/lighting_loop_at_switch.cs4
Thank you my friend. I won’t rush into it.
All the best,
Vijay
